Member postings for Nick Wheeler
Here is a list of all the postings Nick Wheeler has made in our forums. Click on a thread name to jump to the thread.
Thread: Ball Races and 'Brinelling' (whatever that is).
07/03/2021 19:12:32
Posted by duncan webster on 07/03/2021 18:21:29:
Church bells rotate +- half a rev plus a little bit. The little bit is vital, get it right and you can park the bell mouth up, a fraction more and you break the stay, the rope (known as a Sally) disappears up through the hole in the ceiling. Hopefully the campanologist has let go.
???? Every one I've seen has gone from mouth upright, round to upright again. There are plenty of belfry videos that show this. The stay is about another 10 degrees past vertical. It shouldn't break if you just bump it, although learning not to do that is the first thing a beginner should be taught once they're ringing without help.
The rope is called the rope; the woollen grip for the handstroke is the sally.
Thread: Odd car brake issue
07/03/2021 17:24:01
What you've described is entirely normal for single piston sliding calipers.
07/03/2021 17:18:55
Posted by John Haine on 07/03/2021 16:55:35:
There's a chap called Dick Stephen who made quite a few clocks and I'm fairly certain he used miniature ball bearings for the pendulum in at least one of them. I'm not sure of their longevity in that application though. They are used on church bells apparently, where the load is very large, but I guess the actual operating hours are small.
There's nothing special about the bearings used in church bells. They're just pillow blocks, available from any industrial bearing supplier, bolted to the top of the frame. The 1500kg one I ring frequently(when not in lockdown) has been on the same bearings for the last 60years, as have the other, lighter, nine.
Thread: Inherited ML7 in need of some love - where to start?
05/03/2021 14:13:45
Posted by SillyOldDuffer on 04/03/2021 17:08:48:
I'm sure the advice beginners shouldn't leap into stripping a lathe is sound. Peter may have done it successfully, but unwise and unnecessary dismantling is a common cause of problems. For example, even chaps who should know better have broken teeth off their bull-gear by using the wrong technique to get a stuck chuck off.
Another good reason for not stripping down in ignorance is the forum can't tell the difference between problems caused by a faulty rebuild, defects due to wear and tear, and the ordinary difficulties faced by inexperienced operators. The rebuild could be the problem. In many cases it caused the problem!
I agree stripping and rebuilding not rocket science though, and there's no reason why an experienced owner shouldn't get stuck in. It's just a risky thing for a beginner to do on day one. Not everyone is a natural.
The best way to flush out faults in a new-to-you machine is to put it through it's paces by cutting metal. If there's a problem, fix it, otherwise leave it be.
Stripping a machine to its components before you know what is and isn't good is a terrible waste of time. As a mechanic, I would much rather run a machine, even a simple one like an ML7, through its paces before dismantling just to start with an intelligent plan.
Completing such a project not only requires the knowledge to fix any problems, but the motivation, discipline and resources to actually see it through to the end. Those are the real issue; lots of hobby projects are bought for pennies in the pound as a collection of boxes full of part completed pieces because the instigator bit off more than they could chew.
Personally, I would never strip the paint off a used machine as it makes no difference to how it works. The many reports of how much filler was used to make castings look good is another reason.
So it is not negative to caution a new owner(that we know nothing about) about dismantling their acquisition without good reason, but honest practical advice. Or common sense, if you prefer that over used and poorly defined term.
Thread: ER Collet choices
04/03/2021 18:54:15
Posted by Clay Jones on 04/03/2021 18:33:14:
Ah ok, I think I must have missed the obvious in the fact of diameter capacity. Can’t see me needing more than 16mm but is it another case of run with 32 to future proof possible needs in cutters. I’m quickly learning that so many purchase decisions in this hobby are either unnecessary or wrong type....it’s a minefield to the uninitiated Lol!
ER collets are really useful for work holding too. So a chuck for the lathe is a good idea, plus the square and hex blocks make a lot of jobs quick and easy. Which makes buying ER32 a no-brainer
Thread: 2021 AUTUMN SPECIAL
03/03/2021 22:23:59
Posted by noel shelley on 03/03/2021 15:20:01:
I have remained a loyal reader of MEW for over 300 issues ! That there was a need for another model engineering title I have questioned for quite a few years. That MEW was born out of ME may have seemed a good idea at the time but I feel the passage of time has brought it to a point where it is time for ME to take it's rightful place as THE premier model engineering magazine and reabsorb MEW !
Interesting, as I think MEW absorbing ME by publishing strongly edited model build series would be a far better idea! In the twenty years I've been reading these publications, I've probably bought a dozen issues of ME. To me it has enough material to be published quarterly, instead of the fortnightly pamphlet that is still, somehow, excessively padded. Unfortunately its traditional subject matter is now more suitable to forums and simple websites than a published magazine. This is true of lots of niche publications, as the decreasing number of specialist car magazines also demonstrates.
Thread: Collet Chuck for my CL250M?
25/02/2021 11:55:04
Swapping the studs between chucks is daft. I loctited short lengths of studding in all of mine that didn't come with the lathe. I did the same with the mini-lathe when I had it.
Thread: ML7 Hand Crank / Wheel?
23/02/2021 20:18:49
Posted by Dr_GMJN on 23/02/2021 19:52:13:
Posted by Nicholas Wheeler 1 on 23/02/2021 19:42:36:
When I need to to use a bigger tap on my WM250 a 17mm open spanner on one of the chuck jaws works well...
Thanks Nicholas - I keep a large adjustable spanner handy too.
For the work I’m doing it’s small stuff - I’ve only got dies up to about M10, but can’t remember using anything like that big so far.
That's pretty normal for me; I think of M5 as small.
23/02/2021 19:42:36
Thread: Confusing t-slot dimensions
21/02/2021 09:44:42
Posted by Journeyman on 21/02/2021 09:08:27:
You can make T-nuts using the lathe, saves a lot of filing compared to normal rectangular ones!
More detail ** HERE ** if required.
Also true if you have a small milling machine; power feeds and larger cuts save a lot of boring work. It's also a good way of using up stubs of material that are unlikely to be of any other use.
Thread: Skynet is Coming
20/02/2021 23:15:31
Posted by Georgineer on 20/02/2021 21:27:21:
Posted by Bazyle on 20/02/2021 13:37:45:
"The coincidences of discussing something completely random and then being confronted with a connected advert". Sorry Mike I have unfortunately disproved this. I keep shouting "Beautiful Naked Ladies" but so far no connected adverts at all.
Check your Safe Search settings. They're probably set to "Prim'".
Which was probably meant to be "Pimp".
Wrong spectacles perhaps?cheeky
20/02/2021 10:48:57
Posted by Zan on 20/02/2021 09:56:11:
My dishwasher annoys me, we only use one program but it has to be selected with three button ( extreme left, centre then extreme right ) presses not one if you hit the wrong button in the centre the so called eco program runs for 3.5 hours not our normal 29 min......
my camper van control unit had only three buttons one to cycle through then select with another then back to the first to cycle through the changes you need. So frustrating when you miss the thing u want. It failed, repaired, failed replacement costs £300 . So I , ripped it out n replaced it with switches
Four button control panels for multi-function devices annoy me far more than unnecessarily 'smart' ones. You don't have to connect smart features, but are forced to remember which one of several complex sequences of button presses whilst singing the Elbonian national anthem backwards at half speed in a minor key changes from automatic to manual. That's dreadful design, compounded by not having a clear, hardcopy instruction manual.
Touch screens should have reduced this, but the emphasis seems to be more on making the icons look pretty rather than actual use.
Thread: TOPIC VARIETY
20/02/2021 10:34:36
Posted by br on 20/02/2021 10:04:17:
ME editor is as quiet as a church mouse.
This forum is dominated by MEW topics.
A forum for ME and one for MEW would make life simpler.
As another member posted, he has taken his loco build to MECH forum - reason given was lack of interest on here.
This forum's strength is that it doesn't restrict posts to a narrow range of interests.
I've been a member of ones that do, and still look in on others. They often have little traffic, or the same job is repeated over and over. Keeping them going is almost as hard work as reading them. It's like watching Youtube videos where every cut is shown in real time; necessary for a beginner's tutorial, but excruciating for anyone else.
Thread: Dickson holder storage
19/02/2021 18:07:45
This took about 20minutes and £5 worth of material:
and
Thread: Looking to learn CAD
19/02/2021 12:37:31
I won't argue with anyone that CAD programs are complicated, but that's also true word processors and spreadsheets.
What a prospective CAD user needs to be aware of before they start is the underlying concepts, both in general and how each program applies them, but I would suggest that they're a lot easier to understand than those needed for 2D drawing!
Thread: Mini Lathe leadscrew key size?
19/02/2021 10:19:21
By the time you've figured out how to clamp it to the mill, you could have filed it to size and fitted it.
Thread: What tool to use please
18/02/2021 11:46:55
Take the blank out of the lathe and using the angle grinder knock off the corners so it's 'rounder'
That will make your choice of lathe tool less critical because it doesn't have so much to do.
Thread: How Many People Does it Take to Change a Lightbulb on the Forum?
17/02/2021 18:06:41
Posted by peter smith 5 on 17/02/2021 17:38:42:
Bril......but 4 to turn the table around? Should be using B & C not ES.
50 yrs ago my grandparents got this new dangled lectric. My grand mother refused ( no pun intended ) to turn it on or off and I had to change said bulb. Yer cannot beet Aladdin oil lamp and trim wick. Shocking to have to wait till late 1960’s to get lectric lite. Still, going up the garden path, late at night when it’s pi..... down to have last pi... of the day when wind blows out candle, cos no inside loo was the norm. You had it easy!!!
I remember visiting my great-grandmother in the mid eighties, and her cottage and her brother's next door were without electricity. Lighting was gas downstairs, and oil upstairs. Outside toilet at the end of the garden.
17/02/2021 18:02:37
Posted by SillyOldDuffer on 17/02/2021 15:32:27:
I've started a support group for anyone who has been affected by the issues raised by this thread.
It's called 'Coping With In The Darkness'...
Fixed that for you....
Thread: Multi-part assembly drawing
17/02/2021 17:27:28
Posted by Nigel Graham 2 on 17/02/2021 14:22:54:
It takes far more knowledge to draw and print useably by CAD, a simple engineering object; than manually, and you need much innate ability to learn CAD skill; extra to the skills of designing and making which really matter. Software publishers are not good at helping anyone learn their products. Engineering and architectural CAD is really intended for professional draughts-people taught CAD (sometimes even taught to design) in professional trade or university courses. The MEW Alibre course was exceptional in the teaching aspect; at the other end of the scale, the Solid-xxxx publisher's web-site implies being not intended for private users anyway.
You have that completely back to front: just explaining the conventions for representing 3D objects on a flat piece of paper takes far more explanation than being able to orbit around a '3D' object on a screen. Fusion even names each of the six faces Front/Back, Left/Right, Top/Bottom which requires no explanation, and clicking on those rotates the object so you're looking directly at it. One simple sketch can provide all the information to produce a 3D part like a single cylinder crankcase. A quick outline, constrain the geometry, add dimensions and extrude - the same work as drawing just one face. You add features like holes, slots, bosses directly to the face they sit on - what could be easier? And that's before you start on more complex operations like lofting, sweeps, sections, surfaces or moving parts that are very difficult to do on paper.
This all dramatically reduces the skills that a designer needs to create complex and/or multi-part objects from scratch. Creating a 2D drawing is then a simple operation if it's even needed at all; many parts can be made on manual machines from the information directly available from the 3D model.
I had an hour a week of Technical Drawing when I was 13, 37 years ago. That leaves me able to read a drawing, but designing parts in 2D would take me months of instruction, practice and frustration before I ended up with something usable. This model is completely dimensioned, animated with all the clearances worked out over a couple of evenings:
It means that the flat parts can be laser cut from the model, thus saving even more time.
Edited By Nicholas Wheeler 1 on 17/02/2021 17:32:46
