Here is a list of all the postings Mark Eisen has made in our forums. Click on a thread name to jump to the thread.
Thread: How TO Copy And Paste. |
14/02/2020 09:46:28 |
v **LINK** |
14/02/2020 01:59:03 |
I tried the above and this is what I get. I have windoze 10. I was trying to copy and paste some text, rather than type it out all again.
13/02/2020 04:54:48 |
v |
13/02/2020 04:54:47 |
v |
13/02/2020 02:07:38 |
How do you copy and paste on this forum? |
Thread: My Hercus 9 Restoration. |
13/02/2020 02:02:33 |
Posted by Hopper on 11/02/2020 07:42:53:
Ah yes. Good luck with the hunt. You will have a great little lathe for your troubles. Far superior to Myfords and cheap later model stuff. Thanks. |
11/02/2020 07:34:44 |
G'Day Hopper I am just assuming they will be stuffed going by the condition of the rest of the lathe. Am waiting for an order to arrive from Mal. |
08/02/2020 03:23:37 |
Posted by Robin King on 06/02/2020 10:08:17:
Why do you need to replace them? G'Day Robin, Main reason is the lathe is When I pulled the counter shaft assembly apart both bushed appeared tight until I pulled it apart. I soaked the parts in degreaser then blasted it with a 3500 psi gurni, I found this , makes me think the bearings will be just as bad. There are some parts the repeated soaking in degreaser and the gurni would not remove the baked on dirt and grease.
Sorry about the rust, I had it stored on the veranda, last weekend we had our first rain in over two years. |
06/02/2020 09:29:59 |
I back didn't realize it is over a year, got side tracked put a new roof on the house, spent a far bit of the time up and down the track to quacks and hospitals, 1000 km and 500 km south. My new year revolution is to get stuck in to restoring the old girl.
I am looking for the following bearings, can any one give me a heads up where I can get them from? |
Thread: What is This? |
06/02/2020 09:10:47 |
When I bought my Hercus lathe, this came with all the bits ans pieces. Does any one know what it is?
This bit slides back and forwards.
23/02/2019 23:44:07 |
Thank you very much John, I appreciate this very much. Edited By Mark Eisen on 23/02/2019 23:44:30 |
26/01/2019 06:01:12 |
Thanks Robin, got it apart no problems. Is your Boxford Whitworth thread?
25/01/2019 08:38:51 |
How can I get this pin out without wrecking the key? I have tried gently tapping it etc with an success. According to the Southbend Army manual, there is a worm, key, pin and collar.
Thread: Tail stock for turret lathe |
24/01/2019 06:53:56 |
I was just wondering if these are any good? I remember when I was a kid seeing quite a few, but dont hear of these any more.
https://www.youtube.com/watch?v=tUt3P2_lfm0 https://www.practicalmachinist.com/vb/attachments/f25/26629d1285794969-10-6-position-turret-tailstock-any-value-stuff-011small.jpg https://downrivertools.com/plan-sets-kits/bed-turret-plan-sets/mk-ii-bed-turret-for-south-bend-9-lathe-drawings.html Edited By Mark Eisen on 24/01/2019 06:55:16 Edited By Mark Eisen on 24/01/2019 06:56:37 |
Thread: Anyone fitted a DRO to Sieg SC4? |
22/01/2019 07:12:50 |
I put a 2 axis dro on my 9 X 20 lathe, the scales where too high to fit behind the cross slide, so I mounted it on the end of the cross slide, I had to modifiy my backsplash guard. |
Thread: Mini Lathe Rear Tool Post |
20/01/2019 07:48:04 |
I bought one of these for my little lathe. I am quite happy with it. https://www.youtube.com/watch?v=grtiFa56Bpw |
20/01/2019 07:29:07 |
Thanks for your replies everyone Great link Robin, very interesting, I have ordered that Guide to Renovating the South Bend, just got to be patient for our slow mail.
Derek I finally had succuss , the S/Bend tailstock has square recess and the Hercus is dovetailed, I finally got the base off, now just got to get the cap of the end. The bed is cleaned up, All the Hercus I have seen all have been paint red inside the bed except mine.
Hang on whats this.
18/01/2019 10:06:57 |
Posted by Simon Collier on 18/01/2019 08:37:24:
G'day Mark, I have a Hercus ARL. Happily, it is in excellent condition. There are some photos in my albums of dismantling the spindle to change the belt, and a T- slotted cross slide I fitted which was machined from a casting bought from the USA. It is a lovely little lathe. That is a very nice lathe, your lucky to get one in that condition. When I get to my head stock I will have some questions for you. I like your T slotted cross slide very much. |
18/01/2019 09:57:47 |
Posted by Paul Lousick on 18/01/2019 07:55:12:
2 lathes, a hospital bed and a bench on the back veranda, Can't see what the problem is ! I live in Sydney and have been sharing the high temperatures, just not as extreme as yours and have a 9" Southbend (earlier model without gearbox). Good luck with the restoration. Paul.
This warm enough for you? |
18/01/2019 09:50:13 |
Posted by John McNamara on 18/01/2019 08:12:49:
Hi Mark Greetings from Melbourne OZ A Hercus Model A was the lathe I had on the top of my wish list when I was a young man. I still have the brochure! Never did get one due to lack of funds good luck to you with your find, Hercus machines were very well built in South Australia. you will find a real gem under all that dust. I used to live about 45 min from where they were built, though in those days I wasnt interested in wood and metal work. Would you be able to scan the brochure for me? I have a copy of the Hercus 260 if any one wants a copy. |
