Member postings for Ian Symes
Here is a list of all the postings Ian Symes has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford ML7 motor wiring
29/09/2014 11:41:12
Hi Les,
I have sent you the switch photos.
I wiped the internal end of all the contacts and around the tufnol plates, they are sprung together did not see how. It all works fine now.
Thanks Les.
Ian.
28/09/2014 20:19:51
Hi Les,
I went back to the motor and found one of the black cables should have been S and not U2. As labeled in the terminal box.
Then following your connections it all worked. Forward and Reverse, wonderful .
Thank you Les.
I'll send the photos tomorrow when I will be able to reduce their size.
Ian.
28/09/2014 09:12:01
Hi Les,
Thanks for the list of connections, I hope to try them later today.
I do have some photos, only one of them is in focus. I will reduce them and put them on the post.
Ian.
27/09/2014 10:19:02
Hi Les
The contacts A-3 had an intermittent connection.
I took the switch apart and the connection between A & 3 is now good.
Ian
26/09/2014 09:34:54
Hi Les, Thanks for the information. I will re check the terminals this afternoon.
Ian
25/09/2014 13:37:00
Hi Les.
Not a problem, I'll find away round it.
Ian.
25/09/2014 09:33:55
Hi Les.
I live in Dorchester, Dorset.
A long way from some of the model shows I'd like to visit.
Ian.
24/09/2014 23:12:47
Hi Les.
I could take the switch apart but I would like to know what to expect.
If I open it and lots of bits fly out I wont be able to use the lathe at all., I've not seen any pics on line so I might have to get a new switch. I'll give it some thought.
Thanks Les.
Ian.
24/09/2014 22:32:13
Hi Les.
C - 3 when the switch is in reverse.
In the diagram showing the connections that run in forward and reverse, in both cases the switch is in the forward position.
Ian
24/09/2014 11:29:48
Hi Les.
No more just the 7
Ian.
24/09/2014 09:25:22
Hi Les.
I will check the switch position tonight.
The link in the photo is below, in line with terminal 1 looking from the back of the switch and is not marked.
Ian.
23/09/2014 21:51:11
Hi Les,
Thanks for all your help.
3 is connected to C when the switch is in reverse.
Ian.
23/09/2014 14:03:43
Hi Les,
The switch is 3 position.
It is probably the original switch the lathe is on a Myford industrial stand.
The switch position is something I worked out.
I'll check position 3 tonight.
Ian
23/09/2014 12:15:21
Hi Les.
As you can see the photos are on the forum,
thanks to a friend who came into the office.
Ian.
23/09/2014 12:11:10
terminal box.jpgterminal box connections.jpgswitch top.jpgswitch photo.jpgswitch link.jpgswitch end.jpgswitch connections.jpgmotor wiring.jpgmotor layout.jpgmotor end plate.jpg
23/09/2014 10:10:37
Hi Les,
Thanks for the info.
I have converted them to .JPG but still can't load them.
I will try Dropbox when I get home tonight.
Ian
22/09/2014 21:25:14
Hi Guys
I have a similar problem.
I can't get the Stanton switch to switch forward/reverse from the Brooke Crompton motor.
On my Super 7
The switch has different connections to that shown in the manual.
LH from the top, rear view
C B 1
RH
3 2 A
I have drawings on PDF but can't attach them.
Without them the above wont mean a lot.
How do I attach them?
Thanks
Ian
