Here is a list of all the postings Mike guitar has made in our forums. Click on a thread name to jump to the thread.
Thread: WARCO WM-250 lathe family and WM16 mill - 001 |
29/01/2015 21:25:15 |
Thanks Rik on info I'm only applying cutting oil with brush and that leaves quite a residue so understand where your coming from, it does take quite an effort to clean the machine down. I also wear vinyl or even latex gloves to keep the stuff off my skin, unfortunately my garage/workshop isn't as good as yours or George's insulation wise I've given quite a lot of thought towards improving it maybe if I could give the machines a rest I might get round to it!!!! |
29/01/2015 14:42:28 |
Hi Rik congratulations on fixing the oil leak, I'm interested on why your switching to soluable oil? I went the other way I changed from soluable oil to neatcut the main reason being I never seemed to be able to remove all traces of the oil from the ways, evrytime I moved the carriage traces of oil would follow. I don't bother now I'm using neatcut I'm just hoping it adds to rust protection of the lathe. I'm using one of the "Safer !!!!!!" Oils so no residual smell Hope you don't mind all the questions, bet your going to make me worry about the use of neatcut!!!!!! I |
07/01/2015 14:34:59 |
07/01/2015 10:20:54 |
Hi. George and anyone else interested in the rear tool post for the 250-vf lathe, well I've got the pics but a slight Ipad software problem which I'm working on!!!!! The Ipad crashes when I try to load to my album anyway I'll fix it!!!!! Actually I'm puzzling on using the drill chuck which came with the WM16 mill or using an er25collet chuck and a correct size collet. The reason being on my drilling machine which has a drill chuck mounted on an arbour on an R2 spindle any jam say on break through of the drill results in the drill chuck slipping on the arbour and as there's plastic gears involved I thought good safety device. I was therefore thinking the same principle may apply to the WM 16, is it better to use the drill chuck and hope it slips on the arbour if a jam occurs, I'm always over cautious when drilling anyway, just wondered on your thoughts
I |
05/01/2015 16:53:25 |
Heck the IPad spelling not too good today And Echo George's best wishes for the new year Edited By Mike Harris 3 on 05/01/2015 16:54:46 |
05/01/2015 16:52:34 |
Ok George maybe I was tad over exaggerating the heavy bit! But it is quite substantial lump, when I get the WM16 cabinet fixed to the floor and the mill mounted I'll post some pics of the rear tool post.I also bought the parting off blade/holder which works well albeit with a little shimming to set the tool height. I had a damaged swarf tray with the mill but Lindsey at Warco arranged a rapid swap out I've been very impressed with all I've been in touch with at Warco.
23/12/2014 06:10:36 |
Thanks Les, Trev and George, nice pic George, very useful advice from all, Ill be lifting mine after Christmas, Ive got the anchor bolts for the concrete floor so nearly there, I was originally just a little concerned about the weight of the mill hanging on the head suppose it's my age. Actually I'm about to make another posting regarding the new rear tool post and mounting plate I recently bought from Warco, it's a heavy piece of engineering and works well, suppose now I've got the mill I could make one!!!! but for the price what more can I say!!!!! |
22/12/2014 18:56:51 |
Hi, not posted for a while I've been playing with my 250v-f lathe and all going well. Finally got round to buying a WM 16 Mill after lots of searching larger or different mills, anyway unboxed it today and Warco exchanging the stand and machine tray for me as they were a tad damaged. I've checked the grizzly download PDF manual as per the link from George and noticed that they recommend using lifting straps round the head of the mill. I have an engine crane so no problem there, I'm a little concerned about the suggested strap location, was thinking more around the base etc etc,wondered if anyone had lifted their mill on the cabinet with straps shown in the grizzly position? |
Thread: Myford motor failure? |
18/09/2014 15:48:35 |
Hi Derry I'm not sure if the brook Compton motor has a start capacitor or more like I can't remember!!!! You could start by checking if you have, actually it may be a run capacitor again I'm not sure but anyway worth a check. Please ignore my comments if I'm talking out the back of my AC theory |
Thread: warco wm18 versus chester century |
26/08/2014 09:53:34 |
Hi and thanks oompa, I will also make a cabinet for Mill bought cabinet for the lathe but will def build for the Mill, my sons live a few hundred miles from here but suspect their respective wives wouldn't let them help anyway........sign of the times maybe......I've got an engine crane to help me lift it on to it's stand, thanks for your comments |
26/08/2014 08:27:39 |
Hi, I'm getting round to buying a milling machine after wasting years of my life thinking about it. I've read all the web relative advice and taking my age (approaching the big 70) and My wife's increasing frustration into consideration and the fact that machine tools requiring a crane to get them in situ leave me fazed. Hence I'm looking at either the WarcoWM18 or the ChesterCentury I've studies both specs but just know I'm going to get sensible advice on this forum. thanks in anticipation |
25/08/2014 11:17:18 |
Chris and Rik, I have the 250 with the ac delta drive induction motor and up to now I've not had any motor slowing or stalling under heavy load, the only noise is of course from an electronics bay cooling fan which runs all the time from power up but of course this is not objectionable, also I'm from an electronics background so Interested in electronics side of control etc,I've heard several of the dc motor lathes and they all had the hum. I think the ac motor version uses mosfets in the delta control mode, nice quiet operation....so far.... |
16/08/2014 10:45:17 |
Yes Jason I noticed the two washers were a different thickness and to be honest a bit misshapen I used different size d washers from those supplied, interestingly I have a friend who runs his lathe with the banjo always out of mesh, mind he does have several other lathes and doesn't use his warco for threading, I did consider only connecting my gears when threading but then remembered I've got power cross feed!!!!!!! Edited By JasonB on 19/08/2014 15:33:22 |
16/08/2014 08:20:55 |
Thanks Howard, after a few more hours fiddling I arrived at the correct setting, I tried different thickness of paper to get final position, I found the final setting of the banjo to be the most critical.
Edited By JasonB on 19/08/2014 15:36:20 |
15/08/2014 21:25:40 |
Hi I promise not to blag on about the Warco I just thought you may be interested in my progress. Im still considering the saddle stop mods but shelved for the time being and continued messing with the lathe. I decided to give the matter of thread cutting some attention, the Lathe had arrived with the change gears set for a very fine imperial thread so I decided it would be INTERESTING to have a go at moving gears around to give me say 8, 16 and 32 TPI, this didn't give me too many problems once I sorted out the best method of removing/fitting the key sleeves, slotted washers and shafts, I noted that unless the gear train is set up with the correct amount of clearance then the noise transmitted through the headstock is considerable, anyway ive got it sussed now and quite pleased with the result, incidentally the power cross feed works nicelyI sorry for the long script hope you done mind too much Edited By JasonB on 19/08/2014 15:36:47 |
Thread: New warco 250 v lathe |
13/08/2014 20:06:04 |
Posted by john kennedy 1 on 13/08/2014 07:24:27:
Mike, have a look at the mods this chap has done to his 250. http://www.cign.org/sadclamp.html I've done a few of them,including the saddle clamp. Works a lot better..John Thanks John the mods look great, ill start investigating this weekend, ill post any developments on here
13/08/2014 20:04:00 |
Hi Posted by mick pynn on 13/08/2014 09:46:54:
Hi Mike,Ive also bought this lathe two months ago and found this link very useful ,I hope the link works..!!! Hi and thanks Mick, yes the link works fine, brilliant lots of info there and well worth poring over, Ive been messing with the changegears and cutting a few threads etc mine is the imperial machine so again the handbook supplied with the lathe is a brain teaser.,Lots of removing gears etc I think ive got it sussed, Ive discovered the banjo mesh adjustment to be rather tender resulting in considerable change gear noise if incorrectly setanyway thanks again and hope to keep in touch to check your findings etc
13/08/2014 19:41:30 |
Posted by mechman48 on 13/08/2014 06:59:13:
Hi Mike I have the same model only with the earlier motor fitted (bought 2012) & it has the same problem with the saddle lock although with mine I can give the allen key a good pull & it will lock the saddle sufficiently for what I do. It will need the clamping block modifying at a later date, a very slight step machined in it should do the trick but would need some dismantling at the tailstock end so for now I'll leave well alone.. 'If it aint broke don't fix it'... George Thanks George, nice to find and chat to other peeps with the same lathe always useful, I did try and tighten my lock with no success, I'm also not to keen on removing the saddle just yet, for one thing my wife refuses to support the saddle whilst I'm loosening the leadscrew!!!! I'm investigating will post developments |
13/08/2014 19:36:57 |
Posted by Vic on 12/08/2014 17:56:35:
Just a thought, but as you're probably aware in many cases the machines we buy are virtually identical across the range of vendors that supply them. The very best vendor in my opinion for documentation including data and drawings is Grizzly tools in the USA. If you can find your model Lathe in their lineup then download the manual and spare parts list, they will have far more written information than Warco are likely to provide. I should add that I have a Warco machine I'm happy with, the manuals just not very good! Thanks Vic, sorry for the delay getting back, I've been busy checking the saddle!!!!!ive had a link sent to me from another member I,m checking the grizzly site and as so many before have stated the manuals are far more detailed in every respect, I'm also happy with the lathe still fiddling with change gears etc but having taken a few weeks to engine crane it onto its stand and then construct some levelling plates I'm kinda running behind schedule thanks again Vic |
10/08/2014 11:44:43 |
Hi, I've recently bought a Warco 250v-f lathe it's the. New model with a delta controlled ac induction motor, I'm reasonably pleased with the machine, unfortunately the carriage lock doesn't work and the manual doesn't show the engineering details, I've emailed warco and they are getting back to me, I've been informed there's a cam beneath the bed which is tightened down by an Allen screw from the top slide, I suspect I'm going to have to remove the whole assembly to fix the problem just wondered if anyone experienced this problem with the previous dc motor version of the lathe? |
