Here is a list of all the postings Stuart Bridger has made in our forums. Click on a thread name to jump to the thread.
Thread: Dro scale positioning |
17/06/2019 09:28:06 |
On my 2009 VMC, the knee crank handle will clout the edge of the table, when fully wound out, even without a scale fitted. My DRO has on optical scale fitted the rear of the table which was a Warco fit. Edited By Stuart Bridger on 17/06/2019 09:28:28 |
Thread: Electricity Supply |
14/06/2019 12:42:49 |
Ref Ground Source heat pumps. I have been running one for coming up 13 years. Our village has no gas, so it is either Electric, oil or bulk LPG. Our unit draws about 2.2Kw which is not bad for the hot water and heating the whole house. As for costs it was very expensive to install, we did get a small grant which helped a bit. We were laughing when heating oil rocketed a few years back, but oil is cheaper now.
Thread: Can We Be Too Good For Our Own Good - sometimes|? |
12/06/2019 17:10:46 |
Many years ago, I had a new Peugeot 405. I was doing a lot of traveling with work at the time. If I had been sitting in traffic before stopping, on returning to the car I would find a significant amount of the contents of the cooling system on the floor. It took 3 months of back and forth to the dealer with many tests and components being changed before a specialist from Peugeot was called in. It was soon identified that the wrong specification radiator cap had been installed in the factory... |
11/06/2019 11:23:48 |
This talk of "smart chargers" reminds me of the 13 x 9 Wind Tunnel at Brooklands. The operator had to phone the electricity co. for permission to start. The speed meter on the console was overlayed with masking tape segments showing how fast it could be wound up depending on the time of the year. Same issue different scale. That was a 2200HP motor with a 11kV feed into a Ward Leonard speed control system. |
Thread: Horizontal Bandsaw - Final Thoughts |
09/06/2019 21:58:41 |
No direct experience, but based on previous advice, you should take a look at Femi. Much better build quality than those listed. |
Thread: Is CAD for Me? |
05/06/2019 14:43:09 |
Interesting thread. I did start with the Aiibre trial, but have to admit I gave up in frustration when it came to constraints and assemblies. I probably didn't spend enough time on it though. It just didn't seem naturally intuitive to me. I am still working full time in the IT industry and stare at a screen all day, so technology is not alien to me. I do have an engineering background and did 2D drawing at both school and during my apprenticeship. I did dabble with 2D CAD (albeit electrical rather than mechanical) over 30 years ago as well. |
Thread: Connecting a pair of motor controllers. |
03/06/2019 08:24:16 |
I'm no motor control expert, but electronic basics would indicate that the two circuits would need to be kept isolated. This is easy though, you just need a Double Pole Double Throw (DPDT) switch and a dual gang potentiometer. The latter being two pots on a common shaft. Both cheap and easy to source. |
Thread: Does Not Compute |
02/06/2019 13:13:23 |
A couple of years back I got a call from my local bank branch. |
Thread: Colchester Lathe Factory |
31/05/2019 11:40:24 |
Alas my Chipmaster is not as shiny as Alan's. It is still much better than my capabilities though. 1963 model bought from a local engineering shop. Originally supplied to the REME training workshop at Aborfield. Imperial model fitted with dual dials, which I understand is quite rare. Original splash guard went AWOL, so the guys I bought it from fabricated a new one for me FOC. Converted to single phase with a VFD, although retaining the variator. Recent addition is a taper turning attachment. Edited By Stuart Bridger on 31/05/2019 11:42:31 |
31/05/2019 10:40:38 |
Date on of the film? Any more clues? |
30/05/2019 20:22:19 |
Posted by Hollowpoint on 30/05/2019 19:23:10:
The depth of cut on that bell was very impressive. 😯 I thought the same, must work my Chippie harder
30/05/2019 16:40:13 |
Great watch, were all lathes polished up to that level out of the factory or just those for the film, very shiny! |
Thread: Are these spot drills? |
27/05/2019 19:12:38 |
I would say slow helix stub drill, rather than spot drill. |
Thread: HP printer on Windows 10 |
21/03/2019 15:28:34 |
1 - Type "Printer" in the search bar 2. - Find your printer in the list presented, click on it 3 - Click on "Open Queue" 4. - Here you will see the items in the queue, you should able to click and cancel the job here Edited By Stuart Bridger on 21/03/2019 15:36:39 |
Thread: 1/2" x22tpi tap? |
19/03/2019 13:54:17 |
UNS = Unified Special, 1/2 x 22 still isn't a standard size though... |
Thread: Vickers Bl 8 inch Howitzer cannon of 1917 |
25/02/2019 10:59:56 |
Beautiful work and great skills on show here. Seriously impressed |
Thread: which mill |
19/02/2019 10:14:31 |
Another vote for the the VMC, would recommend a DRO as it makes things so much easier |
Thread: Mystery object |
15/02/2019 08:36:06 |
Matrix were (and still are) clutch manufacturers. Only a guess, but some form of alignnment tool? |
Thread: Single to 3 phase invertor and smart meters |
11/02/2019 18:44:09 |
I agree that all the predicted "savings" for the consumer are complete bullsh*t for the majority of customers. I finally relented because I was getting so fed up of being bombarded with information. I have had a new meter for about a month now. My supplier has not yet caught up with the billing. It is a bit of a novelty to see what does and doesn't consume energy, but as others have said, the vast majority of usage is essential. The house is heated by a ground source heat pump, which is 2.3kW. I pay my bill on monthly standing order, whch means I spread the cost of the winter over the year, but on the slipside my account is also in credit for most of the year. It will be interesting to see how more accurate usage impacts this. Time will tell |
Thread: "Vintage" CNC |
11/02/2019 13:13:35 |
Paul, I certainly remember SOLAR/CLASS, the production control system. Certainly the least interesting of all the departments in the porduction phase of the apprenticeship. I have a copy of the manual in my log book. As for green screen VDU's. Single applications were definitely their enemy. When i moved into Electronic maintenance and on inot the hardware side of the IT industry, many CRTs were replaced for screen burn in. But only when they were their last legs. |
