Here is a list of all the postings Robonthemoor has made in our forums. Click on a thread name to jump to the thread.
Thread: Dickson tool post problem |
11/07/2013 22:59:58 |
I'm a newbie lathe operator looks a bit technical. Rob |
11/07/2013 10:45:45 |
Thanks guys spot on, got it apart, the funny thing is, one hex head is half a mm smaller than the other across the flats? Thought I might try braising the hex bigger then filling or milling the hex back to the correct size, will this work or am I been a turnip? Rob |
09/07/2013 22:26:36 |
Derek this is a Dickson tool post is this the same? rob. |
09/07/2013 21:21:38 |
Myford 7 super lathe, dickson tool post, the cam bolt has slightly rounded & the spanner will not tighten the tool holder down correctly, how do I take it apart to change the bolt? Can I get parts. |
Thread: Clarke lathe |
28/06/2013 09:24:20 |
Yes can here the click. thanks Robin |
21/06/2013 18:01:12 |
Tried the safety switch still nothing, & yes the power from the lathe powers the mill. |
20/06/2013 21:37:19 |
i have a clarke metalworker variable speed metal lathe model CL250M PART NUMBER 7610740 RATED POWER 150W 5AMP 100-2000 RPM BATCH 06N. THE OVERLOAD LIGHT WILL NOT GO OUT THUS THE LATHE WILL NOT RUN? ho it as a mile on it as well, it will not run ether. power to the lathe but motors will not run, no noise nothing, help. |
Thread: Forward & reverse wiring |
16/06/2013 23:43:40 |
Spot on" sorted . thank guys |
16/06/2013 21:53:23 |
The switch is a dewhurst & partner ltd hounslow, type A in forward position it reveres in reverse position it runs forward but on a rethink" off is at the back & the switch can't go round to that position so maybe that's the way it works, with the back off the lever pointing at the word. |
Thread: Myford ML7 |
16/06/2013 16:23:50 |
SOBA 100MM DIA LOW PROFILE MILLING VICE can I have your opinion on this one please
16/06/2013 15:16:48 |
My myford super 7 lathe single phase, go's in reverse when in the forward position? Can any one help with this problem, my Electrition says he would like more info before he looks at it.
