Member postings for Brian Jopling
Here is a list of all the postings Brian Jopling has made in our forums. Click on a thread name to jump to the thread.
Thread: Burrell 2" Thetford Town
19/11/2020 23:19:46
Posted by Dave Halford on 10/10/2020 14:38:24:
Why would you fill it with water to run on air?
Looking at Bazyles link
The square block under the motion in the black painted section, if yours has one looks a promising link to connect a compressor to.
Otherwise use a blowdown point, which is probably simpler to use.
Edited By Dave Halford on 10/10/2020 14:40:07
Thanks dave I have used a blow down to fill. My TT has slightly different plumbing to that in your link.
cheers Jopo
19/11/2020 23:17:16
Posted by Bazyle on 10/10/2020 13:38:04:
Is this the type found with a quick google. You could try contacting the website woner for advice on a particular model. Looks like there is a book that would be worth having.
Thanks Bazyle. There is only a injector water feed and definitely no crank driven pump. I have filled and steamed filling via a clack valve. The link indeed shows a Thetford Town with a water pump on the manstand. The book is infact a two volume publication by Alan Marshall that appears to be unavailable world wide. I have seen several different pumps on various TT's and am leaning towards a eccentric on the inside of the flywheel which would not neccesitate much of a stripdown.
regards Jopo
10/10/2020 11:23:50
Somebody must have seen/filled a Thetford 2". Help
08/10/2020 10:59:32
Having retired late I hoped to start a traction engine project. However health has meant a change in plans so I have cheated and bought at auction a very well made 2" Thetford. I am looking for some help.
I intend to run on air to start but would like advice on filling the boiler to make sure the water jacket is full. I cannot see a hand water pump.The engine came with a bicycle pump which may or may not be part of the plan.
regards Brian.
Thread: PTFE or not
18/09/2013 12:40:38
PTFE, very good for bearings but expensive, has a greasy feel is almost (always?) a off dull white shiny finish and is heavy compared to nylon, acetal, pvc.Bit heavier than Delrin but easy to confuse. PTFE machines very well and takes a good finish with a hss flat or slightly negative rake tool with a stoned radius. Back off drills or they will pull in (same as brass)
Do not inhale dust or fumes - wet polish and grind onlysmiley
Jopo
18/09/2013 12:26:49
I would be very wary of inhaling burnt of burning plastic. Many are very toxic
Jopo
Thread: Harrison Universal mill
21/08/2013 16:00:50
John. Time for serious thought methinks.
Jopo
21/08/2013 09:19:50
Thanks for that John. My bed lead screw is in v. good condition and I would like to try the fitting of a speed control to the feed motor first. My plan would be to fit the fastest gear train and vary that.
Would like to know how you get on with your mod - in case!
I also intend to find a suitable dro kit but would dearly love to find a sensitive vertical head (if such a beast exists).
Jopo
20/08/2013 21:58:52
I have a Harrison universal mill and the cross lead nut is worn. Anybody know where spares might be available - or will I have to machine a tap to make a new onesad.
The feed is a seperate motor driven gear box with change wheels - which is a a pain. Anyone converted this to a variable 3 ph speed drive who could give some advice?
Jopo
