Here is a list of all the postings Olaf has made in our forums. Click on a thread name to jump to the thread.
Thread: Schedule of the TB6560-V2 stepper control card |
23/03/2013 13:35:26 |
I the meantime i have got some more Informations. FYI Control signal interface PIN Func Explain 1 EN Enable control signal 2 STEPX X Pulse signal 3 DIRX X Direction signal 4 STEPY Y Pulse signal 5 DIRY Y Direction signal 6 STEPZ Z Pulse signal 7 DIRZ Z Direction signal 18-25 GND GND 10 L1 Input limit interface 1 11 L2 Input limit interface 2 12 L3 Input limit interface 3 13 L4 Input limit interface 4 14 RLY Relay control signal 15 L5 Input limit interface 5 18 GND GND 19 GND GND 20 GND GND 21 GND GND 22 GND GND 23 GND GND 24 GND GND 25 GND GND The drive using six DIP switch to setting current, segments, decay Mode The current is better to closed to the motor rated current. T1 T2 current ON ON 20%*3.5A OFF ON 50%*3.5A ON OFF 75%*3.5A OFF OFF 100%*3.5A Segments Settings When M1 = off, M2 = off, drive segments number is 1,1.8 ? step angle motor turning circle, the whole step = 200 steps / rev. When M1= OFF, S4 = ON,1.8 ? step angle motor turning circle, the whole step = 3200 steps / rev. M1 M2 Segments ON ON 1/8 OFF ON 1/16 ON OFF 1/2 OFF OFF 1 Decay Mode Rapid decay is better when motor has a high speed. D1 D2 Decay Mode ON ON Rapid decay OFF ON 50%Rapid decay ON OFF 25%Rapid decay OFF OFF Slow decay |
19/03/2013 22:38:03 |
Hello, i do own the same red Controller card TB6560 V2 as on the picture from Svarven. And i do need some more information too (DIP Switches, PINOUT). Do anyone hase any further Informations about the board? Thanks in Advance! Greetings Olaf |
