Here is a list of all the postings Yoram has made in our forums. Click on a thread name to jump to the thread.
Thread: Aciera F3 Mill |
02/08/2013 16:00:28 |
Hi Billy. Thanks for the information. I got the mannuels from a site called skydrive.live.com I can't make a copy paste on it, kind of blocked, i got there from google search for Aciera f3 mannuel. after 6 howers of labor i managed to take the pully off the feed box, and only then i could take the box off the mill. Octopus flexability +Elephant's pations. I have many photos in my album. dont menage to uploaded here, and will be thankfull for any opinion . . I undestand that the feedbox pully should be around 150 mm outsid diameter, as i am going to make 2 pieces. Thank you for your help and advise. Have good weekend. |
01/08/2013 23:22:54 |
Thank you Billi and Norman.; Norman- grate explanation thank you!. So my suspitions are propably correct, non of the transmission's pullies is correct size, one too big one too small. the big pully seems to be Pressed on the shaft, no securing bolt, so i shall send the octopus to knock it out, somhow, and make new pullies on the larhe, as long as one do not get bored!! Sorry for the double photos, could not delete one. i will get more close up and detailed photos tomorow trhank you again for the important help!. , |
01/08/2013 23:11:09 |
01/08/2013 19:46:44 |
Pitty i do not succed to put photos here. any secrets about it???? |
01/08/2013 19:45:33 |
Thank you billy. By "gearbox" i reffer to the transmission box that rotates a shaft , 2 "u" joints, and a small gear that moves th table left and right, (X |
01/08/2013 14:58:53 |
Many thanks for the replies. Thank you Ady1, I had registered to Yahoo groups, aproving it takes time.Thanks to Mr. Billy for detailed answer. would you happened t know the diameter of the belt pully fitted to the Aciera gearbox? on the older one i have a 90 MM external diametr pully, the newer one has a 210 MM. (yes, 21 centimeters!) pully, which will not pass thrugh the mills" body" and makes it impossible to remove gearbox from the mill. I am not convinced that even one of them is original, could not find this info in the mannuels. thank you! |
01/08/2013 04:37:00 |
Hi to all! I just bought 2 Aciera f3 mills, one older then the other. Both need some T.L.C. as they are a bit neglected. I have seen the mannuesl as can be found in the net, but still have some unsold issues regarding defferences between the 2 machines, aspecially in the clutch mechanizm, and the x movement of the table. Has anybody has some knowledje / experience of these machines? I will be glad to e mail photos and detailed questions. Thank you ! Yoram. |
Thread: Colchester Bantam Lathe |
03/05/2013 06:21:12 |
Hi Murray. Thank you very much . I had recieved pages from the manual by the kind Mr. John Connagham, but not the manual as a whole. There is a possibility that som information is missing, I would be most thankfull for a link. my mail is yb269ali@gmail.com Thankfully Yours Yoram Binur |
18/03/2013 05:02:11 |
Hi All. I just bought a colchester bantam and looking for parts catalogue or manuel which will anable me to start servicing ang fixing it, as it is in rather neglected state. I could not find it in the net. would be very thankfull for any help. Thank You..
