Here is a list of all the postings Tim Rowe 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Penetrating Sealant |
12/05/2021 13:30:52 |
+ 3 for Captain Tolley's Creeping Crack Cure to give it its full name. It is a low viscosity acrylic compound that cures in the presence of moisture. It will tolerate some moisture in the crack it is sealing. If there is a crack it will "wick" in instantly. When it won't wick anymore the joint / crack is full. Sometimes it needs 2 or 3 goes and works better for that rather than trying to do in in one hit. When cured it remains flexible so is idea when sealing different material and where expansion and contraction are involved. I would be lost without always having a bottle in the cupboard. Tim R |
Thread: Gluing Aluminium |
31/03/2021 08:29:06 |
Hello Stuart I build RC yachts and race IOM yachts. Mine tend to be built for performance rather than scale so are likely to be more stressed than yours. I frequently glue aluminium bits together and only ever use the slow cure Spanish version of Araldite which is always to hand. I have never found it necessary to buy special products or use special processes for the very small usage. I have two types of Loctite that get quite a lot of use on assemblies and fastenings. The important things to do are: Consider the gluing area. Aim to make it as large as possible within the design constraints. I also use brass mainly for decorative reasons and of course that can be soldered. Would that be an option for you particularly if you are not too bothered about weight. One day I am going to try the techniques for soldering aluminium hoping that will enable me to refine my designs. My obsession is keeping the weight out of the hull and rig so I can put it in the keel. |
Thread: Why do plumbing fittings have cast nuts? |
03/03/2021 10:34:33 |
You can also pressure die-cat brass casting a number on the same runner or sprue. It is quite possible that the texture is some kind of post finishing like rumbling before machining. Tim |
Thread: Boat hull formula |
08/12/2020 16:42:42 |
Buffer has it correct. A vessel has to have a positive Metacentric Height to be stable. The cg can be above the cb. If a ship is carrying a very dense cargo such as iron ore, the cargo is built up into a pyramid to raise the cg. Otherwise the ship could be too stable and be over-stressed by the more violent motion this would produce. The is a high speed superyacht that was built with an alloy hull to save overall weight and a steel superstructure to make it less twitchy and more comfortable. It is true however that the other way around is the norm. Tim |
Thread: Scrap Metal Fire |
05/10/2020 15:34:12 |
Looks to me like an exothermic reaction has started. There is a lot of oxygen tied up in rusty iron or steel. Introduce a reactive metal such as aluminium which could still be stuck to ferrous material even after magnetic separation and you have a process akin to Thermite.
Thread: Marine Plastic |
28/09/2018 09:22:16 |
Posted by Clive Brown 1 on 28/09/2018 08:54:53:
For a sailing-boat application, I'd consider Tufnol rod. Widely used for marine fittings, pulleys, rollers etc. Tough, weather resistant, easily machined and not too expensive. Clive. +1 for Tufnol Tim |
Thread: Identity of Glow Engine. |
24/09/2018 18:48:57 |
Keith Tim |
Thread: Small Carronade model - 68 pdr. |
17/09/2018 11:52:14 |
Posted by Bodger Brian on 17/09/2018 08:36:11:
Posted by Mick B1 on 16/09/2018 18:11:33:
OverAll Length. Thanks. That had crossed my mind but I’d dismissed the idea on the basis that overall was one word. Brian For me the most likely explanation is linked to the longstanding and current description for the length of a boat / ship / vessel etc |
Thread: Machine registry |
23/08/2018 15:48:42 |
No Way
Thread: Can anyone identify this? |
30/07/2018 14:04:26 |
I am going to have a wild guess. |
Thread: Very Small Paper V8 Engine |
12/12/2015 08:18:59 |
It'll never run. He did not line up the timing marks! |
Thread: A fishy story |
03/07/2014 11:04:12 |
Go to the sister forum modelflying.co.uk and find out about control line wire. It would seem to have the properties you are looking for. Stainless steel braid. 100% UV proof, flexible and strong for obvious safety reasons. |
Thread: rivets |
30/06/2014 17:38:40 |
Copper and stainless steel are widely used together in the marine industry both above and below the waterline. Many rudder fittings are riveted with copper rods belled over. Above the waterline it is common practice to put an eye in a stainless steel wire or wire rope up to around 6mm diameter. The eye is made around a stainless steel thimble and the tails are crimped together using a talurit which is basically a thick walled copper tube swaged onto the wire with a special tool. Provided the copper is well annealed to start with, you can get a considerable upset. Best to use a fewer number of heavy strokes rather than lots of soft ones as copper work hardens rapidly. On a 6" chimney I would have though 1/4" is as large as you want to keep nice proportions. Go for it! |
Thread: Primer problem |
19/06/2014 06:50:54 |
SteveItee's mate is correct and the old adage that a good paint finish is at least 95% in the preparation. Red Oxide - "Off with its head"! |
