Here is a list of all the postings Hopper has made in our forums. Click on a thread name to jump to the thread.
Thread: "Gearing of Lathes for Screwcutting" |
24/01/2023 21:10:47 |
Nice work. The quick action lever on the quadrant clamp has upgraded your Super 7 to match the Drummond M-Type! |
Thread: Single cam working both inlet and exhaust |
24/01/2023 21:06:57 |
Dougie, if you want to build an old JAP engine, a plethora of original factory blueprints is available for free download here LINK Site says further drawings available from the VVMC. Apparently someone found a microfilm of all the old drawings after the factory closed down. There are guys building their own full sized replicas and classic racing them so might be some web postings on their efforts somewhere. Edited By Hopper on 24/01/2023 21:07:51 |
24/01/2023 11:31:03 |
But don't the Hondas have separate intake and exhaust lobes, on one camshaft? |
24/01/2023 11:15:13 |
Beautiful model engine there. And shows perfectly how the single lobe cam works. Looks like by having the cam followers contacting the cam below the centre line you get less than 180 degrees of cam rotation between when the inlet valve is fully open and when the exhaust valve is fully open. So you could vary the cam timing by raising or lowering the pivot points of the bell crank cam followers. The same effect as varying the lobe separation angle on a normal multi-lobe cam. Edited By Hopper on 24/01/2023 11:17:08 |
Thread: ML7R at Auction. |
24/01/2023 10:58:46 |
Interesting. It has the Super 7 cross and top slides so quite likely is a very late model ML7R. So basically a Super 7 minus the power cross feed and clutch. Looks pretty nice. And the price has jumped up 50 Quid since you mentioned it! Edited By Hopper on 24/01/2023 10:59:23 |
Thread: Why are 3 phase motors with VFD so popular in the UK? |
24/01/2023 10:37:33 |
Posted by SillyOldDuffer on 24/01/2023 09:51:41:... ... The theory of VFDs was understood when I was a boy, probably earlier, but the technology of the day couldn't make a VFD for less than the cost of a small country. And the result was a bit unreliable. And it would have been full of glass tubes or "valves" and taken up a room of your house. |
Thread: 1960 Bullet Albion gearbox obscure item |
24/01/2023 10:33:36 |
Except every other British gearbox I remember working on has the end cover full of the same oil that the rest of the gearbox swims in, in fact you usually fill the gearbox up with oil through a hole in the end cover. Bit unique having the end cover devoid of oil. Certainly Nortons are full of oil there, and from memory BSA and Triumphs and Ariels. But twas a long time ago for the latter three. Very thoughtful of the Enfield chaps to provide a little oil hole to make up for it though! |
Thread: Looking for material for solid tool post mount |
24/01/2023 09:55:30 |
I welded mine together out of a couple of pieces of 1" thick steel plate stacked on top of each other. |
24/01/2023 09:51:41 |
Posted by Dave Daniels on 24/01/2023 09:17:14:
Ariel motorcycle single cylinder 350 & 500 ohv engines had 1 cam with 2 followers NH & VH iirc.
D. Edited By Dave Daniels on 24/01/2023 09:18:29 With strange bell crank cam followers that pivoted above the camshaft, one running on each side of the cam lobe. Some (earlier) models had two lobes, others (later I think) had just one lobe. Famously Sammy Miller's trials bike GOV had the single lobe cam. Edited By Hopper on 24/01/2023 09:52:00 Edited By Hopper on 24/01/2023 09:52:15 Edited By Hopper on 24/01/2023 09:53:46 |
24/01/2023 05:36:26 |
Edit, that last post should read "and NOT the main gear selector like most". |
24/01/2023 05:33:46 |
Posted by John Olsen on 23/01/2023 23:31:05:
When even your washing machine contains an inverter and a three phase motor there must be some advantage to it, probably lower cost. I suspect the smaller size of the three phase motor is enough to pay for the electronics, at least in a mass production situation. I think the big saving in a washing machine is no reduction and reversing gearbox needed to get the back and forth agitator motion. The motor just drives direct and reverses direction at the required intervals. Must save a lot of manufacturing costs on the old gearbox types, which also gave a lot of mechanical problems as they got older. |
23/01/2023 23:10:30 |
It seems quite likely that VFDs will become the norm in the future, as fractional horsepower three phase motors are already cheaper to buy than the single phase ones, due probably to the large numbers of three phase used in industry so mass market equals lower prices. And like all electronics, the inverter/controller units will continue to come down in price as production numbers rise. So eventually single phase motors might die a quiet death as they become relatively more expensive .. |
Thread: Your memories of Live Steam please. |
23/01/2023 21:35:07 |
I travelled a lot on steam trains still in daily use when I backpacked around India in about 1980. Lovely to see and hear. But with all the carriage windows open in the Indian heat, everything inside was covered in black gritty coal ash. Pretty messy and not all that romantic. But it was a great way to travel. I mostly went second class where you had a seat reserved in an alcove with half a dozen other passenger so always plenty of good company and some very interesting conversations. And the food was just amazing. You ordered it at one station, and a station or two later, an Indian curry feast was delivered to you from the station cookhouse. It was a moveable dinner party for sure. Third class was a total melee. No reserved seating and they sold as many tickets as they could. So you had to fight for a seat, or even room to stand, and spend the journey jammed in unable to hardly move. And there seemed to be a less than endearing custom. Each little alcove had a small fan like a desk fan with wire guard around it, suspended from the ceiling. The preferred place for those sitting on the upper luggage rack to put their sweaty sandals to cool off was right on top of the wire guard around the fan, thus blowing fragrant sandal fumes over the passengers below. Unforgettable! |
23/01/2023 21:24:15 |
That's certainly a unique set up. But I guess the end cover holds only the neutral selector and the main gear selector ratchet mechanism like most, so no need for it to be filled with oil. Very thorough to provide a little oil hole for the shaft where it passes through, and a little screw to blank it off. Gotta love old British motorbikes. They all had their very own ways of doing things. I have had my eye out for an Indian Bullet 500 for a while so maybe one day I will get to learn about these esoteric Enfieldisms first hand. Great old bikes. |
Thread: cutting stainless steel sheet |
23/01/2023 12:11:42 |
Posted by Douglas Johnston on 23/01/2023 11:39:07:
Posted by colin vercoe on 22/01/2023 21:09:35:
If you have a 4 1/2" grinder better still a battery one this is probably the industry standard now for jobbing shops and site contract work for steels, cast iron pipe, stainless steel pipe, and sheet use a stainless steel or Inox grade for all as this is a good general purpose grade, grind with a gentle forward and back motion a bit like a surface grinder light pressure dont dwell in one spot or heat will build up causing wheel to glaze this method will fly through 2.5mm sheet, we regularly cut 3mm stainless sheet or pipe up to 6 - 800 mm long.
Yes Colin you are probably right, the only thing is I don't like using the angle grinder in the shed with all the sparks and bits of grit flying about and the weather outside was miserable when I wanted to do the job. I was quite surprised just how well the hacksaw worked. It was not as fast as an angle grinder but kept me warm in the workshop and was quite therapeutic.
Doug Plus one on that. I quite often do the same, having a no-grinding, no-torches policy inside the shed full of leaky old motorbikes. But it is often just more pleasant to hacksaw and file quietly rather than fire up angle grinder and belt sanders and the like. And for you, central heating of the most central type! |
Thread: Mellor Cross Slide Feed |
23/01/2023 11:21:51 |
I think having the tightening knob and the taper as two separate pieces would held too. The knob would screw onto the shaft and push upon the taper piece which would be held captive in the female taper by the knob. You might get away without having to split the taper that way. This would allow you to undo the knob without it being jammed up by the stuck taper and once the knob is loosened off, pressure is off the taper and so it should then let go. Should! |
Thread: Health and Safety |
23/01/2023 11:15:53 |
Posted by Nigel Graham 2 on 23/01/2023 11:01:24:.
One does not like to remind one's MD that he approved Standing Orders that no-one climbs onto these walk-ways without wearing a life-jacket... Ah, but the MD of course is not "no one". He is the MD. That's different. |
23/01/2023 11:14:54 |
Yes obviously a posed pic. Advertising rarely has anything to do with reality. But the unrestrained hair would be the only thing I would worry about. Don't know about UK law but here high vis is not required in workplaces like small machine shops where there is no truck traffic etc. or overhead cranes that might drop a load on a slumbering employee camouflaged in blue twill. |
23/01/2023 11:04:28 |
Posted by Sakura on 23/01/2023 09:41:35:
Thanks Nick, position 4 is the very one. I found several parts drawings on line but not that one. Minor mystery solved! But it still does not tell you what the oil hole/screw is for. I checked my old Royal Enfield service manual and it says all Enfields have a gearbox oil level screw that you take out and fill the gearbox until oil comes out that hole. It says location of the oil hole varies from model to model between front, back and middle of that end cover. So unless you have another level screw there somewhere, that is most probably what it is. Pretty standard thing on old Brit gearboxes. I know Norton, AMC and BSA boxes had them. But never tinkered with Enfields. Your workshop manual should give you the procedure for changing gearbox oil which should mention it. |
23/01/2023 05:20:10 |
It looks a bit similar to the cross feed clutch on a South Bend 9" or one of its clones, Boxford, Hercus etc. so you may be able to copy their set up. AFAIK the Hercus clone just uses a cast iron knob with taper like you have made in brass. Perhaps cast iron or even steel is a bit less "grippy" than brass? Other South Bends seem to have a pair of split tapered "shoes" that the knob and its threaded shaft expand into the surrounding taper. They appear to be cast iron or maybe steel. And I think they have some kind if spring pushing the tapers apart when the knob is unscrewed. One of our Boxford owners should be able to tell us what their cross slide clutch cone is made of. I think they are sensitive to what oil is used in the apron too. Something like ISO32 hydraulic oil would be the norm. Also, it looks like the female taper in your gear could use a bit of a clean up, although pics often make such things look worse than they really are. Edited By Hopper on 23/01/2023 05:21:37 Edited By Hopper on 23/01/2023 05:31:56 Edited By Hopper on 23/01/2023 05:37:13 Edited By Hopper on 23/01/2023 05:38:34 |
