Member postings for Chris Smith 13
Here is a list of all the postings Chris Smith 13 has made in our forums. Click on a thread name to jump to the thread.
Thread: Drummond Shaper
14/03/2017 16:34:34
Hi, Guys. my problem is solved there are 2 holes in the bottom of the bottom casting one either end. mine were blocked of as part of an attempt to motorise the machine so all that was needed was to remove the plugs from each one and unscrew the captive nut easy when you know how. thanks everybody for all the help much appreciated.
Chris.
14/03/2017 14:00:49
Hi John, My Shaper has been modified at sometime to power operation and has had alterations to the bottom casting, which may have had existing holes blocked of to accomodate the changes which may involve the removal of the base casting before I can remove the top! we will have to waIt and see. Thanks Chris.
If I can mention here I also had a Private message from a chap called CHRIS WOODCOCK so if by any chance you read this I have been unable to get back to you so many thanks for your input please join up to the forum properly so I/we can talk. Chris
13/03/2017 20:55:45
Hi, Mick. the lead screw wound out great but the captive nut is attached to the table so it hits the end of slideway and as it lift off I'm a bit buggered.
13/03/2017 10:51:29
Thanks guys i'll try yahoo group, when I tried tilting the top minus gib it didn't want to know even her indoors said it wouldn't come off what do I know thanks.
12/03/2017 19:23:00
Hi, can anyone help me please, I am stripping down a "Drummond" Hand shaper. How do I get the top of the table off? it won't lift off because of the dovetails it has to slide of but the captive nut is in the way how do I remove that any suggestions/ideas would be very welcome.
Thanks Chris Smith
Thread: myford QC gearbox
16/08/2016 10:45:15
Hi everybody!
Thanks to those who responded to my pleas for help, I have now resolved my problem don't know exactly what the problem was I suspect a large amount of operator error was involved? once again thanks for all the help.
Regards Chris
02/06/2016 18:20:17
when the gearbox is used the leadscrew turns correctly until the compound saddle is engaged, this stops the leadscrew turning thus not moving the compound. when looking into the box the selector does not engage the last gear on right, however the selector can go no further to right. I do not think these are related. The lower of the 2 gear trains looks as though it has room at either end of the shaft to move to left to or right, So 2 questions
1 whats is stopping the leadscrew from turning after engagement.
2 why wont the the selector lever engage the last gear
Thread: pulleys
08/02/2016 21:20:57
Robbo
Thanks for info, will try and find some now.
05/02/2016 13:52:19
can anybody help? I have an old Nu-Tool 4/12 inch horizontal bandsaw which has had the motor and pulleys changed .
what size should the pulleys be? the motor runs at 1420 rpm. The current pully is a "2 1/2 motor side to an unknown size on the wormdrive. Many thanks Chris
