Member postings for peter stallard 1
Here is a list of all the postings peter stallard 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Centec 2B
31/05/2023 21:22:24
Hi all, wonder if anyone can help please. I have a Centec 2b engineering milling machine, is there anybody out that can give me any idea of where I can get a concertina for the central drive to the machine, my one has broken ahh!
if anyone can help, will be great
thank you,
pete
Thread: Electrical switch for a Myford ML7
18/04/2019 13:32:52
hi all, wonder if any electrician can help, I have a switch which was supplied from Myford at beeston some time ago , not a dewhurst switch but a square plain forward and reverse switch , photos can be sent if required. I have had to take it apart to release the wiring from under the bench as the lathe is bench mounted, have taken note of the wiring, but a wire has flipped out from a capacitor which I do not know where I t goes, can anyone help please, thanks
peter
Thread: Tom senior
07/04/2019 18:57:30
Hi Plasma, thanks for your reply, there was a question I would like to ask, I have of course taken a lot of photos as I have proceeded with the strip down, but found in the tray I used, a ball bearing and spring, now this may have been in the tray already, but just to make sure, I wondered whether you came across here items on your strip down. I don’t believe there are any ball bearings or springs that are loose in the Tom M1, it could only be from the selector on the top shaft, but this just slots in via a sprung turned knob which was not stripped down. Any thoughts please
07/04/2019 16:39:03
hi, has anyone out there every taken the spindles of the Tom Senior M1 completely apart from the column, some of the bits just do not match the flimsy manual
Thread: Warco WM18 miller problem
14/03/2018 10:41:46
It is a well known fact that although cheaper, in some cases to buy, third world machines are not as robust as second hand British equivalents. The overriding factor is that companies offer accessories with their machines which are attractive to buyers, but this is not always economical, you still pay for those accessories but it is a hidden cost as the machines themselves have such a good markup on profit, you pay for the lack of quality in both the steel and cast iron. Understandably , everyone is on a budget, but it can be a false economy in the long run.
Thread: Adding posts
14/03/2018 10:32:34
Continual log in is a pain , keeps telling me it doesn’t recognise me, been on and off the web site for about 6 years , what’s going on?
