Here is a very useful table of different wire gauge systems.
It give the inch equivalents for the following systems:
The reason wire (and sheet metal) gauges get smaller as the number increases is that the originated as the number of times a wire was pulled through a die to make it thinner (or sheets run through rollers). 18 gauge wire originally meant it had been pulled through 18 dies, so you can see how the use of different sets of dies led to different numberings (such as Birmingham Wire Gauge). SWG was introduced in the UK and AWG in North America to bring some standardisation, but sadly the opportunity to make both sides of the Atlantic the same was missed.
Click this link for a downloadable PDF from the Model Engineer Handbook, published by our predecessor company Percival Marshal in 1960.
Thanks to user Lambton for drawing this document to our attention and scanning it.
Thread | Replies | Views | First Post | |
![]() | Wire Gauge to Millimeters on old plans A caution to anyone translating old plan into metric sizes, especially boilers. By Neil Wyatt | 11 | 3613 | 02/09/2017 09:17:12 by Neil Wyatt |
