This little topslide by D. Scroggins uses a novel approach to the dovetail slides. It first appeared in MEW issue 16, April/May 1993, more details can be found in the archive copy of this issue.
Intended for use on the Unimat 3, it should not be difficulty to adapt the design for use on any other small lathe. Perhaps one could even make a small vertical slide using the same design principles.
Download side 1 of the plan as PDF
Download side 2 of the plan as PDF
Thread | Replies | Views | First Post | |
![]() | New Free Plan - Topslide for a Unimat 3 By Neil Wyatt | 9 | 4427 | 13/12/2016 10:16:05 by Neil Wyatt |
