In MEW 328, June 2023, David George modifies a classic design by George H. Thomas for automatic operation. Full drawings commence in issue 328 and the balance will appear next month in Issue 329.
David explains:
"Having just received a pair of castings for the George H. Thomas screw cutting tool holder, I wondered if I could make it automatic where it would self-extract instead of having a lever to extract the tool. If you are working up to a length you need to wind out the tool at the end of the thread being cut, reverse direction or disconnect the leadscrew and traverse to start of thread. I thought that if the retract could be made automatic I can run the lathe at a faster speed which helps with cutting finish and time to cut thread."
Full details of this device will appear in MEW 328 (out soon!) and MEW 329 the following month. You can pre-order both issues here: MEW Pre-orders and back issues.
To whet your appetite, here are some videos from David:
Thread | Replies | Views | First Post | |
![]() | David George's Retracting Toolholder See an exciting tool to be fetaured in MEW 328 in action. By Neil Wyatt | 15 | 1898 | 03/05/2023 11:40:15 by Neil Wyatt |
