Myford lathe ml7
Problems with reverse traverse
Richard Smith 815/07/2014 20:50:32
1 forum posts
Hi need some help with a myford lathe that my father in law has had for a good while can't seem to get the reverse traverse to engage or work?? We are looking to sell as it hasn't been used for a good while as it was handed down from someone else after we have solved the problem we are looking to sell any help would be great thanks!!! Richard
Robbo22/07/2014 11:19:52
1504 forum posts
142 photos
Can't really envisage the problem. If the carriage will traverse in one direction then it will reverse when the tumbler gears are changed to the opposite setting.
If it will run one way then the gear train must be engaged properly (or it wouldn't), so any engagement problem must be with the second tumbler gear, assuming it is present.
Also assuming the half-nuts are properly engaged every time.
Edited By Robbo on 22/07/2014 11:20:46
Edited By Robbo on 22/07/2014 11:22:51
Mike Poole22/07/2014 11:57:52
3676 forum posts
82 photos
The tumbler gears are different sizes, I would check they are fitted in the correct position. Refer to the parts drawing on the Myford site under the ML7 spares section.
Robbo22/07/2014 23:06:56
1504 forum posts
142 photos
Thanks for that Mike. I forgot to mention that the front tumbler gear is 18 teeth, while the rear is 20 teeth. They may be the wrong way round.
Meant to, but then old age butted in!
