Penrhos Grange by Neville Evans
Drawing errors
terence neary11/05/2013 10:40:58
4 forum posts
I am currently making a 5" gauge Penrhos Grange deesigned by Neville Evans.
A number of drawing errors have become evident. Is nayone else attempting this model?
terence neary13/05/2013 18:29:13
4 forum posts
‘afternoon Michael,
Thanks for the e-mail, I am in touch with Pete Thomas at Polly regarding the Penrhos Grange. However, I know how long things can take especially when you’re are running a business.
I am in no way criticising Neville Evans design I just thought I would alert any other prospective builder to the errors I have found during making the Grange. Most of them a minor but even so can lead to frustration if discovered after a part has be made to drawing. I am working to a combination of the ME articles and the Polly Issued drawings.
I will starting posting in the near future
Terry
terence neary13/05/2013 21:08:16
4 forum posts
Taking the Polly Model Engineering Sheet Numbers or Description in the order in which I made the parts
Sheet 3 :-
Spring Buckle: The 0.149 dimension should be 0.156 minimum to match the radius on the spring Link
Axle box suspension Bracket: The lug is not positioned side ways. It should be positioned to match the hole in the keep plate i.e the centre line of the lug should be .309" from the upper edge
Sheet 10 Valve Gear
Roller die Block: R0.819 should be 4.625
Rocking lever: INA Bearing should be SCE 2-1/2-4
Crosshead link: Diameter 0.125 should be 3/16" to match pin
Crosshead: should incorporate 3/16" Phospor bronze bush.
Sheet 11 Valve Gear Parts & Layout
Eccentric Rods: Upper Rod needs csk pin to avoid fouling Suspension lever bracket..
Weighshaft: Dimension missing, distance between centres of lifting links = 1.431"
More to follow
terence neary13/08/2013 18:14:52
4 forum posts
Valve gear.
Rod Valve: Distance between Hole centres should be 6.882" not 6.682"
Cross head Link: I advise making distance between centres 1.995 not 2.095 to give more flexibilty in setting length of the Piston Valve Rod.
Reverser body
View at left hand side of drawing (forward face) 0.281 dia Hole should be 0.25 Dia to match bush.
Plan view on scale is pictorially wrong since pin is in the centre of the nut and will not reach the extreme ends of the scale as shown.
Stays, Stretchers & Splashers.
E) Front Main Stay: Vertical dimesion of Valve rod Should be increased from 1" to 1.25"
More to follow
