Information sought about the sizing of burners
Tom Dixon 1 | 24/02/2013 20:55:56 |
![]() 9 forum posts | Dear All, I am looking for advice on what size gas nozzles would be required for a gas fired boiler for a friend's 3 1/2 inch single fairlie. The plan is to follow what a gentleman in Finland has done and use a simple to make boiler that looks quite like a Lancashire type with two flues. http://animato.medw.co.uk/3003/060v.html The cylinders are 1.5 inch bore by 2 inch stroke. Regards, Tom |
CuP Alloys | 25/02/2013 08:53:21 |
45 forum posts | Hi Tom Sievert produce a range of propane/air burners that generate from 0.25kw to 86kw running off standard propane bottles. One of these should give you the output you require. See the website for details. Alternatively if you want a ribbon-type burner try birmingham burner ltd best wishes keith
