merlin | 17/01/2013 15:53:26 |
141 forum posts 1 photos | In am trying to put all my emery paper sheets into order of grit size. Some sheets are years old and I would like to check their grades against the new nomenclature. I can't get any response from 'Search' to 'emery paper', 'abrasive' or 'emery' so I must be doing something wrong. Those within the range that I want to check are: 2, 1G, 1F, 1C, 1, 0, 1/0, and there are other finer ones that I know have been replaced by 1200 and 2000. Is there a good website that spells this out? Thanks
Keith Long | 17/01/2013 16:05:26 |
883 forum posts 11 photos | This should give you most of what you wnat or pointers to help.
MadMike | 17/01/2013 20:53:29 |
265 forum posts 4 photos | Merlin why are you worried about "new nomenclature" and grade numbers for such a low useage product. It's only emery paper or cloth after all. Just look at it and/or feel it and then sort and store it accordingly. Simples. Effort should be devoted to real tasks like cutting metal. Incidentally what do you use emery paper for? I bet I haven't used more than half a sheet in 5 years, and then only to polish some stainless steel cap screw heads.
merlin | 17/01/2013 23:49:41 |
141 forum posts 1 photos | Not worried. We're all a bit odd (even tha'?) and it is one of my pleasures to have things tickety-boo in my workshop: if the emery paper manufacturers have gone to the expense of making and marketing differing grades then I may as well store them ready for use in that order. I knew these grades by heart when I worked with them in the early sixties. The differences are not easy to feel or see. I could easily spend time with the heater on and minus five degrees outside, noting the effects of various grades on a sheet of metal but I thought that someone here could advise me, which they have done. After a long break I am back working on the clock and about to polish the centre arbor. I am very out of date. What would you use to get a really high polish on a roughish turned silver steel 3/16" x 3" rod? Perhaps there are labour-saving modern diamond-using that I don't know about. What variety of model engineering demands only half a sheet of emery paper or cloth in five years? .
