which coal to use
Ben Clarke30/12/2011 21:46:11
6 forum posts
I have a 7 1/4 " gauge steam locomotive. large loco, 5 feet long.
Which coal should I use?
Do I need a special steam coal or does it really not matter?
mgj30/12/2011 22:58:42
1017 forum posts
14 photos
I have a 3" LS- so I'm not sure if one is comparing apples with apples.
Anthracite I am not too fond of. It burns very hot and it seems to like a lot of draught, so its either white hot or dying and nowhere in between.
I've used various types of steam coal- seems to burn more red than white, but its not so up and down so I find it rather easier to use. But then I have also had some (theoretically) steam coal which clinkered very badly after hard work, and left the grate clogged.
Housecoal they say is pretty good - akin to steam coal. I like the smoke (which you don't get with anthracite). I didn't built a steamer to be all eco.
A lot has to do with getting the lumps the right size for the grate in use.
Truth is I doubt it matters, so long as you have grate, blast nozzle and coal sizes, and blower nozzle size set for the stuff one is using, but I prefer steam coal, or failing that a mix of anthracite and steam coal, using plum sized lumps.
Ask at the club, see what they suggest for such a loco and then give that  a go - see whatt happens? At the end of the day its a steam engine - ain't that critical and ain't exactly rocket science.
Edited By mgj on 30/12/2011 23:00:55
Tony Martyr31/12/2011 16:16:47
226 forum posts
45 photos
Ben
You should avoid the very bituminous coals because, unlike the steam coals (which have a very high carbon content) they can clog the fire when the lumps weld themselves together.
My first attempts at firing a 31/2" loco were completely frustrated by using house coal. In any case house coal is a very variable mixture some with high ash and silica contents and other, like mine, with high tar content. It is worth getting steam coal from a specialist supplier. I got mine from a guy at the Midlands Exhibition in October and start the fire with kerosine soaked BarBQ charcoal and have no clogging problems since.
