Stewart Hart | 08/12/2011 08:14:28 |
![]() 674 forum posts 357 photos | Picked these castings up at the anual club auction
They are off an inside valve loco and have a pert number 3/102 cast into the side, look as thogh they could be off 3 1/2" gauge loco as they will bore out to 1" does anyone recognise them. Thanks for looking
Stew |
Richard Parsons | 08/12/2011 14:28:31 |
![]() 645 forum posts 33 photos | Yes they are almost certainly Locomotive cylinders. They would have been for a locomotive which had outside cylinders with the valves inside the frames. I had a look at MyHobbystore plans and they may well be fopr a ‘Rob Roy’ but I would suggest that you go and have a look your self Rdgs Dick |
Stewart Hart | 08/12/2011 14:51:50 |
![]() 674 forum posts 357 photos | Thanks for pointing me in the right direction Dick
They are indeed for Rob Roy, I have a copy of Martins Evens excelent book on building Rob Roy, and ran my rule over the castings and they match up with the drawing in the book.
Dont know what I'm going to do with them if anything, they were a real bargan having checked out their cost at Reeves, I had it in mind to use them for a twin cylinder vertical marine engine, but I think that would be a bit of a beast.
Thanks again
Stew
Richard Parsons | 08/12/2011 15:24:11 |
![]() 645 forum posts 33 photos | A twin Cylinder Marine engine … Why not. All you will need to do then is build a Yarrow or Scott Marine boiler and a suitable boat. Or how about making a horizontal mill engine, with its Lancashire boiler and a cotton mill for it to drive. Or you could build a Rob Roy One other suggestion why not sell them and buy something you realy want/need Rgds Dick |
