A double hook, imported from China, succumbed
dcosta | 05/03/2011 23:47:28 |
496 forum posts 207 photos | Hello!
I had my milling machine mounted on steel bench over a mobile base with wheels that allow vibrations and did not allow for height adjustment in the four corners and therefore could not level it adequately. When my wife took the old mobile base out and then at the time that would insert a new base, the router that was about 10 cm above the floor fell with a crash.
Following is the picture of the hook which succumbed. It had the shape of an open 8. I hope that what happened to me does not happen to someone. Best regards Dias Costa
Edited By Dias Costa on 05/03/2011 23:57:22 |
Jeff Dayman | 06/03/2011 00:29:35 |
2356 forum posts 47 photos | Very glad no one was hurt, it could have been very bad indeed.
You can't depend on formed steel wire hooks for lifting anything heavy. Forged steel hooks or welded chain hooks only should be used, nothing made in China should be used, and never get ANY body parts under any object in the air in my opinion.
My general rule/opinion for lifting is that if a lift setup looks good, double up its' strength and still stay out from under it. Same sort of thing for load rating numbers when buying hooks links pulleys straps etc- load them up to only half what they are rated for. I've had some close calls with shifting and lifting and now I take no chances. Rating numbers on Chinese goods are not to be relied on. I got this message the hard way when a Chinese engine hoist rated for 1200 lb collapsed with a 550 lb car engine on it during a straight vertical lift with no side load. No one was hurt but it wrecked the front of the car and damaged the engine badly. Of course I restrained myself to say only "tut tut" and "oh dear" at the time.
JD
Nicholas Farr | 06/03/2011 08:05:35 |
![]() 3988 forum posts 1799 photos | Hi Dias Costa, yes good to hear no injuries. can only agree with Jeff, use reputable lifting tackle and don't ever get any part of your boby under any thing that is up in the air or on jacks ect.
I have a 500kg set of chian blocks on a overhead gantry in my garage, would probaly take a 1000kg, but have never tried it.
Regards Nick. Edited By Nicholas Farr on 06/03/2011 08:06:03 |
