colchester bantam
Ian MILLARD20/01/2010 14:51:10
18 forum posts
hi i am thinking of buying a colchester bantam lathe. can anyone tell me if a vertical milling slide can be fitted to the top slide and if the mandrill has a morse taper for mounting arbours. thanks ian
John Whitby26/01/2010 18:32:09
5 forum posts
The Bantam is a great machine, never regret buying mine.
It has a morse taper, I think it's a No4 1/2  but comes with a reducing sleeve to take a No3. The cross slide is solid - no tee slots but it has a number of tapped holes which could be used for fitting a vertical slide. I don't think Colchester ever made one (and it would cost a fortune if you found one!) but you could make one up, there was a very  good conversion of a cross vice in an early issue of MEW.
I have turned up some morse taper tooling to fit in the nose of the Bantam and hold items like driving wheels for turning.
