Sourcing Template Paper
Jim K | 16/11/2009 11:16:26 |
66 forum posts 28 photos | Hi does anyone know a good source for template paper / card in the uk or any cheap alternatives that are used, i know i can use the lokes of cornflake boxes for small stuff but i am looking to cover maybe 1 metre square.
Jim K |
Niloch | 16/11/2009 11:24:26 |
371 forum posts | In my experience the people who stock the greatest variety of card are picture framers of whom there must be some in your locality. The first of the following wholesale contacts will supply non-trade users but I'm not sure about the second one: (1) http://www.lionpic.co.uk (2) http://www.wessexpictures.com Edited By Niloch on 16/11/2009 11:25:04 |
Geoff Sheppard | 16/11/2009 11:36:34 |
80 forum posts 1 photos | The last time I looked, the local Hobbycraft store had a large range of suitable materials
Geoff S |
Jim K | 16/11/2009 11:46:56 |
66 forum posts 28 photos | Yes i have thought about craft shops and picture framers but i thought the card would have beed too thick and expensive as it is for decorative purposes.
JimK |
Niloch | 16/11/2009 13:32:13 |
371 forum posts | Thinnest mounting board is 1.25mm thick but more commonly 1.4mm. But then there is barrier board/card placed behind the image to prevent impurities migrating from the MDF/hardboard back onto the image causing foxing and a whole variety of problems which is 0.75mm thick. Typical size would be 1020mm x 815mm. Corn Flakes packets are about 0.5mm thick aren't they? |
Mike Bashford | 16/11/2009 14:44:42 |
4 forum posts | I don't know where they get it from, and have never used it personally, but carpet fitters use template paper - I recently had vinyl fitted in the bathroom and the fitter used a roll of thick paper about 6 feet wide and many yards long - he fitted it as if carpet, and then used it as a template to cut the plywood to cover the floorboards. It's a very thick, strong, matt grey paper. |
Niloch | 16/11/2009 16:31:07 |
371 forum posts | Mike's suggestion seems to be a good one; do you have a supplier to the flooring trade in your area like this one? |
Jim K | 16/11/2009 16:40:25 |
I have a friend who is a carpet fitter i will have a word with him, I never knew they used such a thing but it all sounds logical that it should to cut the ply etc.
What had been in my mind was when I was an apprentice in the training school we used an orange template paper in the plating shop for drawing out developments etc. I am sure the stuff the carpet fiters are using is very similar.
Thanks
JimK |
