Newton Tesla CL series
Fitting to a Boxford Lathe
Jim K13/11/2009 03:17:20
66 forum posts
28 photos
I am sure there are owners here who have fitted this conversion to an under drive lathe,
I am thinking of adding this modification to my lathe or simlar so please recommend other options. My question is when fitting the conversion do you fit the motor in the original position and use the same pulley drive system, or do you rip it all out and modify to have a more direct drive.
JimK
Edited By Jim K on 13/11/2009 03:17:41
John, Newton Tesla13/11/2009 23:46:22
1 forum posts
Hi there.
The standard motor supplied with the Newton Tesla CL750 lathe speed control systems is a direct fitting replacement for most Boxford underdrive machines (same shaft diameter of 5/8", same centre height and same foot fixing centres). All except the Boxford VSL machines which had the same frame size of motor -  but fitted with an electro-mechanical brake on the non-drive end.
You can keep the existing pulley system.
On our elderly Myford ML7 lathe - we tend to leave the belt arrangement in a mid-speed range and then let the speed control do the rest.
Hope this helps.
Regards,  JohnJN
John Wood121/12/2009 16:03:54
116 forum posts
Hi,
I have recently fitted the CL750 controller to my Warco WMT300 with great success. As John does with his Myford I leave the lathe's belt on a medium range and simply use the Teslar speed control - it's magic!
Regards   John
