filling a gas tank
stevieboy | 01/10/2009 23:10:58 |
10 forum posts | so how do we fill this gas tank then? do you have to purchase a proper propane valve or can one make the valve, and what sort of gas refill can do you use ,is it the same as you would use for filling a gas lighter? Does the tank have a safety valve? if the heat shunt used is too hot does the tank vent via this vavle or if it gets that hot is it likely to explode? |
