M1 Miller
Lube
graham williams 123/07/2009 13:08:44
13 forum posts
Have a Tom Senior M1 miller, believed later model ,as the power feed quill from the g/box on the column side to the table feed goes straight into the back of the table not to a separate gear with it's engagement lever on the RHS.
Need to know how to fill the table reservoir with oil, it's very low in the sight glass, as nothing obvious as to how to fill it.
Any advice appreciated.
Cheers
Antony Cook23/07/2009 21:40:13
12 forum posts
Good evening Graham,    I have a similar machine and get oil to the table gear through (or over) the end cover of the saddle (right hand end of course).  I usually wind the table as far to the right as possible, remove the two bolts securing the handle and push the table further as far as possible.  It is just possible to see the oil level inside with a torch.  I say this because I will have to "degunge" the sight level om my M1as it is blocked at the bottom.  This is, as far as I know, the only possible way to get oil into this part of the miller.  Hope that this helps.
Antony Cook23/07/2009 21:43:50
12 forum posts
Posted by Antony Cook on 23/07/2009 21:40:13:
Good evening Graham,    I have a similar machine and get oil to the table gear through (or over) the end cover of the saddle (right hand end of course).  I usually wind the table as far to the left as possible, remove the two bolts securing the handle and push the table further as far as possible.  It is just possible to see the oil level inside with a torch.  I say this because I will have to "degunge" the sight level om my M1as it is blocked at the bottom.  This is, as far as I know, the only possible way to get oil into this part of the miller.  Hope that this helps.
Antony Cook23/07/2009 21:44:33
12 forum posts
Antony Cook23/07/2009 21:49:25
12 forum posts
Sorry about the repeated postings...  As you will read on my second attempt, the table should be moved to the left looking at the M1 from the front..
graham williams 124/07/2009 07:30:44
13 forum posts
Hi Antony.
Thanks for that info, will give it a try and see how I get on.
Cheers
Graham W
graham williams 124/07/2009 07:32:09
13 forum posts
Hi Antony,
Thanks for the info, will give it a try and see how I get on.
Cheers
Graham W
