Myford S7 clutch pulley shaft fitting
Moving the motor-drive belt-guard backplate
Nick Passmore26/09/2023 11:57:22
21 forum posts
Could anyone familiar with the Myford S7 help with a sanity check?
I would like to move the motor-drive belt-guard backplate a few millimetres further away from the countershaft mount (to suit a new 3-phase motor, the shaft of which is slightly short).
Have I understood correctly that the whole cone pulley and clutch assembly can be withdrawn without dismantling the clutch if I remove the grub screw from the cone pulley and the circlip next to that pulley? I could then introduce a couple of spacer washers behind the backplate.
Norman Billingham26/09/2023 12:54:34
56 forum posts
Yes. If you loosen the drive pulley grub screw, you can slide the pulley towards the tailstock, That gives enough clearance on the L to get a strong pair of bent circlip pliers in and release the circlip from its groove. The whole clutch/countershaft assembly will then slide out. Be careful not to lose the woodruff key, or the ball bearing in the RH end - both have a habit of vanishing into the depths of the machine - I'v never found my woodruff key - it was easier to buy a new one!
It's best not to dismantle the clutch unit - it has a powerful spring it it which can come out sharply and is difficult to compress back into place.
Nick Passmore26/09/2023 13:08:26
21 forum posts
Many thanks Norman. Will pay close attention to small parts liable to escape!
Nick
