Durhambuilder | 06/10/2022 09:14:39 |
77 forum posts 5 photos | Currently building a 5“ Tom Rolt as drawn by Don Young. I’m going to use ptfe or similar for the piston valves rather than DY’s forced fit iron ones. Should I use round ports in the valve liners to minimise risk of damaging the ptfe bobbins or should I stick to square ports? Cheers. |
Fowlers Fury | 06/10/2022 11:13:24 |
![]() 446 forum posts 88 photos | IMHO (and relatively ignorant opinion), I'd always use square ports.Steam admission & exhaust is sharper. Filing round holes square in liners is easy enough, if tedious. |
SillyOldDuffer | 06/10/2022 11:38:58 |
10668 forum posts 2415 photos | My concern is PTFE expanding into the hole and then being cut by it's edge(s). I guess a round hole would be more efficient as a cutter, imagining the PTFE expanding into the hole as the piston slides over it until it reaches the half-way point where it then is nipped and sliced by the reducing semi-circle. But maybe a square hole is worse because there's more edge to cut. A long run experiment would show the difference and how bad the effect is. Possibly the answer is to chamfer the edges to stop them cutting as the PTFE expands. Cast-iron rings don't expand into a hole in the same way - they push evenly all round the cylinder. Dave |
duncan webster | 06/10/2022 14:11:26 |
5307 forum posts 83 photos | Chap in our club had a Simplex with carbon filled ptfe slide valve. This worked fine against a rectangular port |
