Low viscosity 100% clear 2-part epoxy
Rowan Sylvester-Bradley13/08/2022 13:30:54
88 forum posts
I'm looking for a low viscosity 100% clear 2-part epoxy in a double syringe, with not too fast setting time. I need it to repair cracks in some china items, so it needs to flow well into the crack before starting to set. Can you recommend a product that will do this?
Thank you - Rowan
Norman Billingham13/08/2022 15:08:37
56 forum posts
No direct personal experience, but Fynebond, Hxtal NYL-1, Epotek 301-2 and Araldite 2020 are all used by ceramic restorers. Hxtal NYL-1 was used to repair the Portland vase so should be good enough for most purposes. I'm not sure if any of them comes in a double syringe though - it's usually better to mix by weight than volume.
DC31k13/08/2022 16:25:53
1186 forum posts
11 photos
I think the low viscosity requirement is directly contradictory to the syringe dispensation method.
There is a luthier on YT, twoodford, who uses a suction cup (like you would see on a soap holder that sticks to your bathroom tiles) to massage adhesive into cracked guitars.
pgk pgk13/08/2022 17:27:08
2661 forum posts
294 photos
Not what was asked but I’d be tempted to try one of the clear light-set glues which might be drawn in via a fine wire or thin hypodermic needle and can be built up in layers.
Perhaps this sort of thing: ebay
My experience with such items was with dental work using way more expensive kits so this isn't a direct endorsement of the product link but such products have been around for a long time now so i see no reason why it shouldn't work. The lining product I used was as thin as water (after etching enamel with phosphoric acid paste) and then adding layers of colour-matched pastes to complete the fillings.
pgk
Dave S13/08/2022 19:31:52
433 forum posts
95 photos
Try here:
Huub13/08/2022 22:01:37
220 forum posts
20 photos
I use Bison Epoxy for these jobs
Link
Breva13/08/2022 23:37:33
91 forum posts
7 photos
A de-soldering pump fitted with a soft rubber hose fitted on the nozzle ( to give a good seal against the surface) gives a quick short vacuum and can help to suck glue into a crack.
Joseph Noci 114/08/2022 07:59:59
1323 forum posts
1431 photos
Try Smooth cast products - maybe from benam.co.uk -
Kristal 6 or 30 ( epoxy based)
Kristal
Crystal Clear 20x series ( urethane based)
Crystal Clear
Both yellow in direct sun with long exposure, both remain clear for 5 years so far indoors.
The urethane is easier to use.
How will you keep a low viscosity material in the crack? A fast cure would assist, but the requirements are contradictory - all the epoxies/urethanes I find tend to have long(er) cure times for low visc. types - fast cure types also shrink more, and have higher viscosity.
