Anyone know to lubricate them?
Stuart Cox 3 | 23/01/2022 18:37:28 |
130 forum posts 25 photos | Hi all Does anyone know how to lubricate the bearings in the mill head of the Clarke CL500M? Many thanks Stu |
old mart | 24/01/2022 17:58:18 |
4655 forum posts 304 photos | If the bearings are taper roller, I would recommend a high melting point lithium grease, as used for older car wheel bearings. Be sure to leave at least 50% air space when packing them. |
Stuart Cox 3 | 24/01/2022 19:09:18 |
130 forum posts 25 photos | Thanks, I'm not sure if they are tapered bearings as I haven't taken it apart yet. I was hoping someone who has managed to do this could advise?...... |
old mart | 24/01/2022 19:53:05 |
4655 forum posts 304 photos | I found the parts list, they are very likely taper roller, but that grease would work with any ball or roller bearings. Why do you want to replace them? |
Stuart Cox 3 | 24/01/2022 20:16:37 |
130 forum posts 25 photos | Thanks, I don't want to replace them, I just want to know how you get to them to lubricate them. I'm presuming I don't have to strip the mill head apart every time they need lubricating.... |
Stuart Cox 3 | 24/01/2022 20:17:17 |
130 forum posts 25 photos | ...or maybe I do? |
SillyOldDuffer | 24/01/2022 20:40:25 |
10668 forum posts 2415 photos | Can anyone confirm the bearings need maintenance? I've an idea they're sealed for life and are replaced if they clap out. Dave |
old mart | 24/01/2022 20:57:41 |
4655 forum posts 304 photos | I agree with SOD here, they are probably not intended to be lubricated during their lifespan. The manual should show lubrication points and there may not be any mentioned for the lathe spindle either. |
Stuart Cox 3 | 24/01/2022 21:06:12 |
130 forum posts 25 photos | All it says in the manual is .. 'Lead screw and mill head spindle should be oiled weekly '.... so maybe you're right. The bearings are a little noisy so looks I may have to replace them then. Thanks Stu
old mart | 24/01/2022 21:28:41 |
4655 forum posts 304 photos | Strange, I downloaded the CL500M manual from the Clarke website, and the routine lubrication on page 23 does not show any lubrication of the milling spindle. |
Stuart Cox 3 | 24/01/2022 21:48:03 |
130 forum posts 25 photos | ..page 23 under the heading Weekly |
Stuart Cox 3 | 24/01/2022 21:49:40 |
130 forum posts 25 photos | ..although there's no diagram or reference though show how to oil the mill head spindle |
old mart | 24/01/2022 22:10:33 |
4655 forum posts 304 photos | I can see the oiling of the quill lever spindle, that is all there is on the mill . |
