Stripped down
Carl Dorling | 22/03/2021 19:17:14 |
84 forum posts 69 photos | Hi all , I thought I should add some pictures of my project |
Carl Dorling | 22/03/2021 19:18:46 |
Edited By Carl Dorling on 22/03/2021 19:32:33 |
Carl Dorling | 22/03/2021 19:33:21 |
84 forum posts 69 photos | |
Carl Dorling | 22/03/2021 19:33:50 |
Carl Dorling | 22/03/2021 19:34:29 |
Carl Dorling | 22/03/2021 19:34:56 |
Carl Dorling | 22/03/2021 19:35:34 |
Carl Dorling | 22/03/2021 19:36:48 |
Mick Dobson | 23/03/2021 08:42:14 |
41 forum posts 27 photos | Carl, The mandrel bearing arrangement is different to my lathe, which has separate bearing caps and two fixing studs each, rather than the split cap with single pinch bolt on your lathe. Is it definitely a Dreadnought? The bed should be cast with the lettering Dreadnought below the headstock area. Unless of course they changed the headstock design at some point? |
Carl Dorling | 23/03/2021 10:14:46 |
84 forum posts 69 photos | Hi Mick, the bed is stamped with dreadnought and all the parts have number 5 stamped on them I’m wondering if this was one of the first made due to the earlier headstock design. |
