Bull wheel
Carl Dorling | 16/03/2021 19:25:51 |
84 forum posts 69 photos | Hi, I have discovered the bull wheel is past repair does anyone know what the teeth count is . |
Mick Dobson | 16/03/2021 20:29:32 |
41 forum posts 27 photos | Hi Carl, I'll have a look tomorrow after work. Regards, Mick |
Mick Dobson | 17/03/2021 19:20:32 |
41 forum posts 27 photos | Hello Carl; The bull wheel has 75 teeth. Regards, Mick |
Carl Dorling | 17/03/2021 19:37:05 |
84 forum posts 69 photos | Thank you Mick , and would I correct in saying that it’s 16DP . |
Brian Wood | 17/03/2021 19:44:02 |
2742 forum posts 39 photos | My apologies Carl for inadvertently leading you astray. Clearly the Dreadnought is a very different lathe to the ordinary Portass versions which were I believe Myford clones. Regards Brian. |
Carl Dorling | 17/03/2021 19:53:44 |
84 forum posts 69 photos | Good evening Brian, no problem I’m learning all the time. |
Mick Dobson | 18/03/2021 19:21:16 |
41 forum posts 27 photos | Hello Carl, For your question regarding the bull wheel. Yes it is 16DP, same as the change wheels. Regards, Mick |
Carl Dorling | 12/04/2021 14:30:23 |
84 forum posts 69 photos | Hi All, I have had a good look at the lathe and noticed more differences to all others I can find pictures of, it has a short rack and a different apron to others that and the headstock design plus the number 5 stamped on all parts leads me to believe this was a very early example so possibly quite a rare lathe definitely worth saving. |
