Eric Clark describes how he fitted a readily available faceplate to a Hobbymat MD65 lathe.
Roger Sambrook | 07/02/2021 18:33:14 |
3 forum posts | I am looking to acquire an old Haighton Cadet lathe faceplate having a 3/4 x12tpi thread form. Can any body help with either locating this item or supplying a copy of the original deign to enable me to produce the faceplate. I await in anticipation regards Roger Sam.brook |
Howard Lewis | 08/02/2021 14:36:49 |
7227 forum posts 21 photos | If no drawing is available, how about measuring the mandrel onto which the Faceplate will fit? Length of thread (You already know the size / pitch ) Diameter of register (If any) Length of Register Diameter of Faceplate can be whatever you wish; withing the limits of the maximum swing Thickness, again whatever you wish. Sensibly, it will probably be not less than 1/4" and not more than 1/2". Probably 3/8" How many slots, and the dimensions, will, again, be your choice., possibly inspired what pictures you may have seen, in catalogues, or websites, such as Lathes UK. Howard |
