Very large beam engine
Graham Titman | 31/10/2020 15:46:29 |
![]() 158 forum posts 28 photos |
It is all brass or bronze the fly wheel is 9 1/2 inches diameter i think the bore and stroke is 1 1/2 by 3 inches the eccentric straps look like they are press out as the corners are very sharp .The main shaft i replaced so i could turn the engine over the one it came with had sheared off at the flywheel the 3 eccentrics are have a key way in them i have taken the studs from the steam chest they are .122 48 tpi and if i remember the eccentric straps are 3.5 x 1 mm pitch bit off a mongrel any help would be greatly appreciated Thanks Graham
roy entwistle | 31/10/2020 19:13:11 |
1716 forum posts | Studs and all fastenings are probably imperial |
