Roger Hart | 18/10/2020 15:32:05 |
157 forum posts 31 photos |
Inside is a typical power supply based around a BD3216 chip. A close look shows the mains fuse ended in a dry joint with a black burn mark. Also L3 the buck inductor is missing, it came away with the potting - it too seemed a bit cooked. The mucky soldering on the led assembly is original. From a quick trace of the circuit the transformer is part of the Vcc power supply and feedback loop. Now to think of a use for it... |
