Myford ml7 cross slide strip 6 holes
Timothy Hannam22/06/2020 09:17:36
1 forum posts
I've just bought my first myford it's a ml7 1954 need to buy a new cross slide strip gib which has 6 holes 8 1/2 inches in length myford only offer a 4 whole strip ,did contact myford they will not be helpful English company that I had hoped for, Don't think it's a long version can anybody help please
ega22/06/2020 22:08:36
2805 forum posts
219 photos
As no one else has responded I will try to help.
I was surprised to find that Myfords supply the gib strip with dimples already machined regardless of the number of adjustment screws. As you say, they seem to list only a four-screw item which I think is for the standard length cross slide. You seem to have the desirable longer slide.
I have one like this which is, as you say, 8.5" long, It has six adjustment screws at 1.625" centres and I have added two lock screws and two dowels to prevent relative movement between gib and slide. A gib to suit this would be easy enough to make from mild steel strip with its edges milled or filed to correct angle. It would then be clamped in position and marked for drilling the dimples, etc.
This kind of work is covered by G H Thomas in his Workshop Manual which I suggest would be a better use of your money.
Good luck!
David Davies 822/06/2020 22:21:28
202 forum posts
+1 for the George Thomas mod and his books are well worth reading.
