Grease gun thread
Adrian L22/05/2020 12:55:45
10 forum posts
Hi all.
Can anyone help me please?
I'm wanting to replace my grease gun nozzle, the bit that actually fits over the zerk/grease nipple. The reason being I've recently bought a Clarke hand operated grease gun and I couldn't get the darn thing off again without a load of hassle. I've seen the G coupler and this looks to solve the problem, this is available with a 1/8th BSP fitting which I think I may require, when I've done a bit of ringing around, but they couldn't give me a definitive answer.
I've had a thread gauge, marked as metric, on the existing thread on the gun and it looks like a '28' thread, does this convert as a 1/8th BSP does anybody know?
I measured across the tops of the grease gun thread, that came out as 381 thou which converts as 9.67 mm.
Thanks in advance.
Martin Connelly22/05/2020 13:13:34
2549 forum posts
235 photos
1/8" BSP is 28 tpi with a tapping drill size of 8.6mm so 9.67mm diameter on the outside of the thread sounds reasonable.
Martin C
mgnbuk22/05/2020 13:14:59
1394 forum posts
103 photos
1/8" BSP is 28 tpi & 9.5mm OD - Google "BSP threads" for a choice of thread charts.
The odd grease gun I have had to change nozzles on have had 1/8" BSP threads.
Nigel B.
old mart22/05/2020 13:22:19
4655 forum posts
304 photos
The only other similar thread is 1/8 NPT which is 27tpi. Using something to seal the threads when you assemble the joint will even work well if there are mismatched threads.
Adrian L22/05/2020 13:52:03
10 forum posts
Hi all ,
Thanks to all replies so far, that's given me confidence to order the fitting as 1/8th BSP, great stuff.thumbs up
