Crabtree isolator switch/Myford MG12
Ian Armstrong27/04/2020 18:07:04
17 forum posts
Hi all
I hope you are safe and well
Can anyone help with pictures of the fitment of the bias spring on a Crabtree machine isolation switch? Mine is fitted to a Myford MG12 cylindrical grinder and is situated at the bottom of the door, with the function of precluding you having a mostly live machine with the door open.
The spring should return the lever to the 'off' position with the door open, so it engages with the switch when the door is closed.
Thanks
Ian
Andrew Johnston27/04/2020 19:06:09
7061 forum posts
719 photos
Posted by Ian Armstrong on 27/04/2020 18:07:04:
Can anyone help with pictures of the fitment of the bias spring on a Crabtree machine isolation switch? Mine is fitted to a Myford MG12 cylindrical grinder and is situated at the bottom of the door............
Yes, but not right now as I'm going to do a bit more gardening before it honks it down over the next couple of days. I'll give mine (also on a MG12) a clean and take some pictures tomorrow morning.
Just a thought, is the spring you mention on the handle on the door, or on the isolator proper inside the cabinet?
Ian Armstrong27/04/2020 21:47:41
17 forum posts
It is the mechanism on the door. One end of the spring is tethered to the through door fastening screw, the second is somehow connected to the barrel in the centre- that is what I'm looking to understand.
I'd mail a picture, but haven't worked out how to append one here yet. Not sure if the forum software likes Firefox
Rgds
Ian
Andrew Johnston28/04/2020 09:55:35
7061 forum posts
719 photos
Pictures of the lever and spring, in the OFF position:
And the ON position:
The spring is pretty weak, wouldn't pull the skin of a rice pudding. The geometry is such that the spring tends to move the lever to whichever setting is selected. It certainly won't return a lever in the ON position to the OFF position. Given that you can't open the door with the lever ON I can't see why you'd want the spring to return the lever to OFF?
Ian Armstrong28/04/2020 10:36:07
17 forum posts
That is perfect!
My set up has been abused prior to me opening the door. It is missing the lug that the spring locates in.
That lug, whilst logical, is new news to me
I think my logic is with the door open the main switch is 'Off' biasing the knob/lever on the front door to 'Off' also means when you shut the door, the pin on the switch and the mating groove in the barrel line up.
Can you point an infrequent user to how you attach photos? I have to icons for image and insert image, that don't appear to allow easy navigation to files on my PC.
Many thanks
Ian
Andrew Johnston28/04/2020 11:05:48
7061 forum posts
719 photos
Pictures need to be uploaded to an album before inserting in a post. Here's a link to a "how to post pictures" thread:
Ian Armstrong28/04/2020 11:10:44
17 forum posts
Thanks for your help Andrew
Andrew Johnston28/04/2020 11:11:43
7061 forum posts
719 photos
Posted by Ian Armstrong on 28/04/2020 10:36:07
Logic is good as far as it goes. But you can't open the door with the lever in the ON position. The only way to open the door is with the lever in the OFF position, which is where you wanted it in the first place. smile
Andfrew
Ian Armstrong28/04/2020 11:32:19
17 forum posts
We might be strongly agreeing.
No expectation of the door opening with the switch set to 'On'
Two stable spring positions makes sense. What wouldn't, would be a door that need an intervention to get it to close ie if the spring caused the knob to default to the 'On' position with the door open.
Ian Armstrong28/04/2020 12:04:17
17 forum posts
At first thought, I imagined that the item I call the barrel was missing a lug, and that had been snapped off. On inspection there is no sign of damage on mine. I suspect the part that looks like a lug is also where I have a drive recess.
Do your photographs actually depict a headed pin with a hole in it?
Ian
Andrew Johnston29/04/2020 11:04:09
7061 forum posts
719 photos
The lug is part of a serrated pin that holds the shaft on the lever to a collar with slots in it to drive the contactor. If that's not clear I can take pictures, or create a sketch.
Ian Armstrong29/04/2020 14:08:48
17 forum posts
Again, thanks. I removed (what was left of ) the pin to see a crystalline fracture point where the head shown in your picture should have been.
All clear to me know. Next a small turning job.
Rgds
Ian
