Philip Sewell | 18/10/2019 21:50:27 |
26 forum posts 14 photos |
I've no idea what the other things are. Any ideas, Thanks Philip.
Edited By Philip Sewell on 18/10/2019 21:53:12 Edited By Philip Sewell on 18/10/2019 21:57:21 |
John Haine | 18/10/2019 21:57:58 |
5563 forum posts 322 photos | Hard to say without photos! But it may be a fitting to use the 40int taper with an automatic change tool holder system. |
John Haine | 18/10/2019 22:25:59 |
5563 forum posts 322 photos | Aha! Better. The thing on the right is a pull stud for an int taper toolholder to adapt it for use in an ATC on a CNC mill. The drawbar has a clip on the end that grabs it. Other bits look they might be alignment aids. |
Martin Connelly | 19/10/2019 19:07:30 |
![]() 2549 forum posts 235 photos | If the flat topped tool is a metric or imperial length (measured to a reasonable tolerance) it may be a height setting pillar for items that are quite tall when clamped to the machine bed. Martin C |
Philip Sewell | 19/10/2019 20:26:03 |
26 forum posts 14 photos | Ok I now understand how the pull stud works, it helps when you know the name of something to google it, thanks. I'll check the height of the l/h tool tomorrow, I wonder why the r/h tool is turned to a point. Also, why have flats been machined on the bases, and grooves machined in those flats. Philip. |
John Haine | 19/10/2019 20:41:12 |
5563 forum posts 322 photos | Do the bases fit Tee slots perhaps? |
