Unimat 3 milling spindle bearing upgrade
Former Member10/08/2019 17:46:14
Kiwi Bloke11/08/2019 03:01:31
912 forum posts
Well, I'm full of admiration for someone who fixes a problem so swiftly! In disgust at their bearing slackness, I packed away my Unimat milling heads and tried to forget about them. Perhaps motivation will now return...
When you had the quill apart, did you investigate whether a standard-sized ball bearing could be fitted into the nose end of the quill as well? Presumably, it would need to be bored out, as at t'other end.
Former Member11/08/2019 08:54:55
Kiwi Bloke11/08/2019 11:05:59
912 forum posts
Barrie: thanks for your encouragement and offer. I've no idea when I'll get one of those round tuit things... Where did you go for Bellville washers?
I see that Simply Bearings (from whom I've had excellent service) have 15mm ID bearings in 20, 21, 24, 26 and 28mm OD. Perhaps this makes a nose-end bearing swap practicable. What do you think? My spindles have a lot of radial play at the nose end, so I'd want to attack that end as well.
Former Member11/08/2019 12:46:02
