"split" return crank will not tighten on shaft
David Bothwell 1 | 27/07/2019 16:25:53 |
204 forum posts | Came across this problem while re-fitting new return crank, I used a cap head screw (2.5 m.m.) and steel nut, but it will not tighten, just wondering if anyone has a suggestion? Possibly incompatible nut (7ba.) I have copied the original part( and consulted the drawings) but the original builder decided to make a split and fit a nut and bolt to grip it to the shaft. I did have the engine running with this method, but the return crank "moved" (engine would not go!) any suggestion gratefully received. Also is there a "fool-proof" way of setting the return crank in the right position in respect to other parts of the motion? Thanks in anticipation! |
roy entwistle | 27/07/2019 16:36:54 |
1716 forum posts | Use the same thread on nut and screw |
Speedy Builder5 | 27/07/2019 19:03:01 |
2878 forum posts 248 photos | Is one of them left handed. |
Jim Nic | 27/07/2019 20:04:41 |
![]() 406 forum posts 235 photos | What is it that won't tighten - is it that the nut won't run down the thread? If the engine was running and then the shaft turned in the split crank it suggests to me that the split is closing fully before the crank grips the shaft. In which case make the split wider. Jim |
David Bothwell 1 | 27/07/2019 21:00:19 |
204 forum posts | Thanks for the replies, I will try the solution in the morning! The nut goes down he thread but there is no tightening up I am fairly sure this is because the bolt is a metric thread and the nut is B.A.. at least I think this is the problem |
Mike Poole | 27/07/2019 21:10:41 |
![]() 3676 forum posts 82 photos | Just to be pedantic BA is a metric thread Mike |
David Bothwell 1 | 28/07/2019 07:56:14 |
204 forum posts | Of course you are correct Mike, I have looked at the conversion chart and there is a difference between 7b.a. and the "metric" equivalent. thanks for the replies most useful. |
