Opposed Piston Engine of Wolfgang Tepper
Frederic Frenere24/03/2018 17:50:18
12 forum posts
I have read the article in the March 2018 magazine Model Engineer in which Mr Wolfgang Tepper is describing his Opposed Piston Four Stroke and I am wishing away time until I can read the next installment!
For many years I have been mindful of such a project. There is much to interest the builder in this design of engine, with great potential to power a variety of projects.
The success of the concept is greatly proven, by Junkers and others, perhaps most famously the British Napier marine and locomotive 'Deltic'.
I hope that Mr Tepper considers publishing his design for interested enthusiasts to study more closely.
Fred.
Howard Lewis25/03/2018 16:55:39
7227 forum posts
21 photos
Being pedantic, the Commer (Tilling Stevens) TS3 , TS4, Napier Deltic, Rolls Royce K Range, Fairbanks Morse, etc opposed piston engines were ALL scavenge blown two strokes. The phasing of the opposed pistons, and port spacing along the liner gave the induction and exhaust timing for reasonably optimum performance.
Think that the Junkers Jumo engines were also opposed piston, and that the TS3 and TS4 were based on this concept of large rockers between the piston con rods and the single crankshaft con rods, to make the engine more compact.
The General Motors V71, V92 etc and EMD engines were single crankshaft, uniflow two strokes, which allowed them to be turbocharged, as well as the scavenge blown, naturally aspirated versions..
Not sure if an opposed piston four stroke would work, purely on port timing. (Ports would be opening when they were ought to be closed). Sleeve valve, perhaps like the Bristol Radial aero engines, and Daimler Silent Knight engines?
Clive Foster25/03/2018 17:41:34
3630 forum posts
128 photos
Sleeve valves would work fine to make a four stroke opposed piston engine. Whether four stroke has any advantages in that configuration is different matter. Maybe from pollution control but I'm sceptical.
Professor Timoney did some interesting work on improving the efficiency, economy and peak power output of the TS 3 motor which could usefully be followed up exploiting modern technology. Basic concept was to put the rocker arms connecting the pistons to the crankshaft on eccentric bearings that could turn to vary the piston stroke. Stroke variation was self acting under the control of a simple spring and damper arrangement. The engine was able to operate at near constant BMEP over a wide speed and power range for better economy, especially at light loads, when the stroke was longer. Also gave higher peak power at full throttle but short stroking considerably increased fuel consumption. Timoney later added an exhaust turbine coupled into the transmission drive line to get useful work out of the exhaust. Major benefits under high throttle short stroking conditions. Apparently worked well on the testbed but the relative complexity meant it wasn't considered commercially viable at that time.
Maybe something like the rotary exhaust expender unit proposed for CREEV and similar Wankel based systems would be a better approach than the exhaust turbine. At least the operating RPM would be the same as that of the parent engine making coupling easier. Secondary expansion, with a bit of after burning if need be, also seriously reduces nitrous oxide emissions.
There has long been considerable interest in exploiting the opposed piston motor, Achates being just one relatively recent entrant. But no one has been able to make the push into production.
Frederic Frenere25/03/2018 19:10:52
12 forum posts
Yes, I'm aware that they were two stroke diesel with blowers. Mr Tepper's design uses poppet valves contained in a central carrier ring, which also contains the spark plug (although the designer states that it will 'diesel' on ether fuels). Camshaft operates the valves via rocker arms. There are three connecting rods. It is a four stroke by definition, which clearly works as it has been completed. A very interesting project.
Fred.
Edited By Frederic Frenere on 25/03/2018 19:12:33
Edited By Frederic Frenere on 25/03/2018 19:15:36
