5" TICH setting the quarterig
Kevin Bennett29/09/2017 10:07:17
193 forum posts
56 photos
Hi Everyone I am at a point if setting the crank on my 5" tich and fixing to the shaft .what side is the lead crank also the fixing to the shaft key ways or press fit
Thanks Kevin
Clive Brown 129/09/2017 11:52:49
1050 forum posts
56 photos
Convention says RH crank leads, but doesn't really matter. On my Simplex I went for a very light, (not tight !) interference fit, smeared with Loctite 601. I did turn down a section of the length by 1 or 2 thou. to give clearance for the Loctite.
I added a "french key,". 1/8 inch dia. pin in hole drilled half in wheel hub, half in axle.
Edited By Clive Brown 1 on 29/09/2017 11:55:32
Edited By Clive Brown 1 on 29/09/2017 11:57:32
Kevin Bennett29/09/2017 16:42:37
193 forum posts
56 photos
Thanks for that Clive a big help
Thanks Kevin
