Stewart Hart | 06/06/2017 17:08:22 |
![]() 674 forum posts 357 photos | Our club has been donated a Kennet Tool and Cutter Grinder like this http://www.lathes.co.uk/kennett/ its complete with all the bells and whistles except for the belt which is no problem and the grinder wheels. So the ? is does any one know the correct size of wheels for the grinder and a supplier. Cheers Stew
John Baguley | 06/06/2017 17:42:44 |
![]() 517 forum posts 57 photos | Hi Stew, I bought the complete kit from MES and the wheels came with it. I can measure them up if it would help. John |
Stewart Hart | 07/06/2017 07:19:11 |
![]() 674 forum posts 357 photos | Hi John
That would be a great help, thanks.
I've read through your build for this grinder:- great work
The electric motor is rated at 2800 rpm as recommended, the pullies look to be 2:1 giving a wheel rpm of 5600 could you check what the ratio is of your pullies are. Thanks Stew
John Baguley | 10/06/2017 11:20:52 |
![]() 517 forum posts 57 photos | Hi Stew, Sorry for the late reply. The wheels that came with the kit are: 1 off 100mm x 40mm straight cup Green grit - code number GC80-K42 1 off 100mm x 40mm straight cup white aluminium oxide 1 off 75mm x 10mm plain disc white aluminium oxide 1 off 50mm x 25mm taper cup white aluminium oxide 2 off 80mm dish white aluminium oxide The wheels are all 12.7mm bore and 80 grit and labelled Consort. The white whels are all coded WA80-JV1. The motor that I used was one I had to hand and is 1440rpm. The small pulley is approx. 1.5" diameter and the large approx 5.2" diameter giving a ratio of approx. 3.5. This will give a spindle speed of approx. 5000rpm. Hope that helps, John Edited By John Baguley on 10/06/2017 11:23:18 |
Stewart Hart | 11/06/2017 08:43:34 |
Thanks for the information I'll put it to good use.
Cheers Stew |
