clayton gearing
gears used
David Watson 311/02/2017 09:56:24
51 forum posts
I have been unable to find the magazines that published the modified gearing for the Clayton rear axle. I assume the 40 tooth on the diff and a 10 tooth on the lay shaft. I had thought of a 10 on the crank shaft to a 20 on the lay shaft. The brackets for the lay shaft wont be a problem.
Nigel Bennett11/02/2017 10:24:28
500 forum posts
31 photos
ME 1991 - No.3894, p389. Ron Cockerill was the author. The layshaft provides for a 2:1 reduction in addition to the 4:1 of the Dyer design. I've fitted it to mine (See ME no. 3944, 1993).
Let me know if you can't access the articles and I'll scan and pm them to you.
David Watson 311/02/2017 11:35:04
51 forum posts
Hi Nigel, Thanks,PM sent.
