HARRISON M300
GEAR BOX NOISES
HUGH CONNELL02/01/2017 11:59:55
6 forum posts
8 photos
Hi Everyone
I am Hugh From Alcester Warwickshire
I have a 1991 Harrison m300 . In all ranges except the lowest on it sounds smooth and quite normal , In the 58 and 260 it sounds a bit rattly is this normal the chuck runs smoothly enough.
What is the best oil for the top and bottom gearboxes can someone recommend a supplier the boxes have been recently flushed and filled with what I have been told is the correct oil.
MalcB02/01/2017 19:35:20
257 forum posts
35 photos
Hi Hugh,
Good advice would be for you to join the Yahoo Harrison User Group. There are loads of files you can access and download including oil charts. Plenty of other useful info as well.
You can also access and download a pdf copy of the manual, which has the lubrication charts.
Top gearbox is a thin ISO 68 hydraulic type oil. Bottom gearbox I am currently working on grade update comparisons but its an ISO 220.
Think some oil traders on Ebay actually list specific oilsfor the M300. As for Brands, you will never go far wrong if you can get Castrol in economic quantities. The machine capacities are much less than you would think.
As for gearbox rattles i would say that they are never really welcome. There is a few Youtube videos where there have been similar issues which at the end of the day have just been put down to wear and tear with no real cost effective solution. Its an easy job to lift the gearbox lid and check for visible damage, but avoid running with it off as oil will fling everywhere. I would just make sure you are correctltly lubed up if nothing visible is obvious.
Malc
Edited By MalcB on 02/01/2017 19:43:37
Edited By MalcB on 02/01/2017 19:51:08
Andrew Johnston02/01/2017 20:11:12
7061 forum posts
719 photos
Posted by HUGH CONNELL on 02/01/2017 11:59:55:
I wouldn't say my M300 was rattly in any of the speed ranges, but it certainly isn't quiet. I rarely run at top speed, as there is a distinct whine. Probably due to spur gears in the headstock rather than helical.
I use a standard ISO68 hydraulic oil in the headstock. For the feed gearbox I use a straight ISO220 oil.
Peter Trueman02/01/2017 20:22:00
4 forum posts
I also have a M300, I am in Stratford so very close to you, I did some research and now use iso 32 in the headstock
and 75 weight in my gearbox which suits its temperatures in my garage from very cold to hot summer days.
I recently removed my gearbox to replace a chipped tooth which caused a similar rattly noise.
Mine does not rattle in any speed ranges now.
HUGH CONNELL03/01/2017 20:05:47
6 forum posts
8 photos
Hi Peter
thanks for the reply
I thought a chipped tooth might be the cause, although when I looked a few days ago nothing was evident
ill have another look. Why hydraulic oil I thought EP gear oil would be the stuff. I do Have the book on the lathe but most listed are no longer current
Hugh
HUGH CONNELL03/01/2017 20:14:34
6 forum posts
8 photos
thanks for the help was hoping someone would say the noise is normal. ill look again
and let people know what I find
Haven't got to grips with this site yet send message or post?
Ps is e-bay the best place to buy oil. in Redditch locally they only had 25lt at over £100
Hugh
Graham Wharton03/01/2017 20:41:10
149 forum posts
48 photos
Beware of just picking any old ISO 220 grade gearbox oil for the quick change box. The Harrison M300 calls for a specific grade of gearbox oil that does not contain EP additives. Certain gearbox oils containing EP additives are known to attack yellow metals such as bronze and brass, which can be found in your M300 gearbox.
For Shell Oils the following name changes/equivalents apply
Shell Vitrea 220 -> Shell Morlina S2 B220
Shell Tellus 68 -> Shell Tellus S2 M68
Both of these are available on ebay in small quantities.
Carl Wilson 404/01/2017 23:34:23
670 forum posts
53 photos
The yahoo Harrison group is good. Learned a lot about my M250 there.
A guy called Rupert Powell did a large amount of fault finding on a gearbox noise on his M300. Could be worth a look.
