john mitford | 16/10/2016 15:45:58 |
1 forum posts | hi all just brought this little myford ,i need a chuck 4" but unsure on the model ,if anyone has one for sale ,i need one thanks myford lm970 |
Dusty | 16/10/2016 16:04:45 |
498 forum posts 9 photos | John It would help us to identify your lathe if you could post a photograph of it. |
Swarf, Mostly! | 16/10/2016 16:48:04 |
753 forum posts 80 photos | Hi there, John and all, John, your post ends with 'lm970' - please explain. It is possible to be led astray by numbers and letters cast in to lathe beds or other parts. Depending on the drawing system used by the manufacturer, these can be the part number of the bed, pre-machining, or even the identity of the foundry pattern rather than the identity of the complete lathe. I have also seen lathes listed by eBay sellers attributing them to the manufacturers of the motor! Or to the Sales agent. In the case of the Myford 7 series, the Super Seven and the ML7R actually bear a label (when new) giving their identity but, so far as I know, the good old ML7 doesn't bear its name - in the absence of experience, it has to be identified from the Myford sales literature, the various books featuring it, or Tony's web-site, Lathes.co.uk. The ML1,2,3&4 can usually be distinguished from each other by comparison of centre height or whether the drive is via flat belt or vee belt. Best regards, Swarf, Mostly! |
Georgineer | 17/10/2016 22:13:07 |
652 forum posts 33 photos | John, If you do a forum search for 'Myford ML3' you will find a thread started by Sean Logie. On the second page I wrote a longish post outlining the differences between the Myford ML1,2,3 and 4. If your lathe is one of those, it may help. If it's one of the other models I can't help. George |
