how to adjust
Robin teslar | 12/01/2015 14:48:41 |
![]() 127 forum posts 8 photos | Hi Myfordians I noticed on my venerable ML7 that I have rather more end play than desirable and would like to tighten it up. Having looked at the gear with a slotted grub screw tapped endwise on the mandrel, and also the steel thrust collar with grub screw, so its not quite so simple. Before messing about in ignorance, would any kind users please suggest my best move. If its covered elsewhere, apologies please advise link
Cheers
Robin
Jon Gibbs | 12/01/2015 16:23:18 |
750 forum posts | Hi Robin, Have you joined the Myfordlathes yahoo group? This file... **LINK** may be of interest. HTH Jon |
Brian Wood | 12/01/2015 18:12:40 |
2742 forum posts 39 photos | Hello Robin,. The ML7 headstock has the same sort of adjustment for end float as had been used on the ML4 The collar with the grubscrew inboard of the end gear on the spindle is used for setting, it is fitted on a threaded portion of the spindle. Remove the grub screw to check if there is a copper or brass pad below it to prevent damage to the threaded section and screw it up to remove the surplus float. Refit and nip up the grub screw and check that your chosen setting has been held. There should be slight resistance to turning the spindle, without any belt drag, when gripping the chuck nose thread by hand. Best done on a cold machine. I hope that helps Brian |
